![]() | Home > Maintenance & Modifications > Brake fluid change |
| ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967
Does anyone flush theirs ?
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
yes and clutch at the same time
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817
Brake fluid is hygroscopic, so absorbs water. Therefore irrespective of whether you drive few or a lot of km, brake fluid should be replaced every two years on every car.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
Yes, I changed mine recently Solved the bowel problem, working on the consonants...
| lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1343
Did mine as part of the three year service in the summer.
Picked up a tip from the forum on removing most of the old fluid from the reservoir 1st to save wasting a load of new fluid. I think it's good practice and it helps to prevent the bleed nipples from seizing up as well. |
| Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767
Yep, regular as clockwork.
With a pressure-bleed kit it is a quick & simple operation (used to use an Eezibleed but have had a Sealey VS820 for a few years now and it is excellent). ONE LIFE, GET IT! |
| All times are GMT |
