Home > Tdi > hmmm what goes here.....?
xcentric
Crawing around underneath my 200tdi to fix yet another starter motor failure, I notice this, which I suspect has something missing from it.
And now I'm wondering if it's not the starter motor that won't turn, but the engine..... Big Cry
what fits there, and how significant is it that it's missing?!! What size something plugs the hole? Anyone have a part number?
Post #588658 30th Dec 2016 12:47pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
is that where the wading plug would go?
Post #588660 30th Dec 2016 12:51pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
That is the bellhousing drain hole, prior to any jaunt off road / through water you are ment to for the "wade plug" in here to prevent it filling with crap. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #588661 30th Dec 2016 12:53pm
shaggydog
Just the wading plug hole, nothing to worry about.
Also used for timing the engine when required.
Otherwise all looks quite clean and ordinary Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #588662 30th Dec 2016 12:55pm
xcentric
thanks, all. Do people actually bother with wading plugs, or not? if so, where to get one (or two) from?
cheers.
Thumbs Up Thumbs Up
Post #588663 30th Dec 2016 12:57pm
dorsetsmith
Post #588664 30th Dec 2016 12:59pm
shaggydog
I have lost both of mine Embarassed
They did use to see regular use when I was doing much more regular and deep off road work but in the last year I have not needed them once.
Worth getting a pair to keep in your dash in case you need to wade or be in mud that deep. I wouldn't recommend running for long periods with them in as they are useful for letting you know when your seals are leaking and needing replacement. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #588821 30th Dec 2016 9:38pm
jst
yes they are worth bothering with if you in mud/water alot, especially the timing belt on.
better to fit when needed them remove to allow anything to drain out when they are not fitted. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #588838 30th Dec 2016 10:07pm
xcentric
ok I'll show my ignorance Smile where does the other one go then?
Post #588882 31st Dec 2016 12:25am
shaggydog
One in the bell housing, one in the bottom of the timing belt case Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #588884 31st Dec 2016 12:27am
jst
here: https://www.google.co.uk/search?q=300tdi+w...N68zlvM%3A
bottom of timing belt housing Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #589021 31st Dec 2016 7:08pm
