Home > In Car Electronics > Random fault - radio stays on and cigarette lighter TD5 Def
AJC
Hi folks. I have searched for the answer but can't see anything.
My head unit and cigarette lighter have always turned off with the key. However it randomly the other week stayed on. I keyed back on and off and it went off.
Now it always stays on as does my cig lighter when keys removed. I haven't messed with anything so I think a wiring fault is to blame. Can anyone suggest anything? Thanks
Post #588195 28th Dec 2016 6:04pm
dorsetsmith
radio and cigarette feed from the same point on the ignition switch white and orange wire down to the passenger fuse box and also heater
1. Try removing white and orange wire from ignition switch may the switch at play up
Post #588198 28th Dec 2016 6:23pm
Romadog
Sounds like you may have some wear in your ignition switch that could bring up other issues in the near future. Maybe best to look at changing soon.
Post #588207 28th Dec 2016 6:40pm
Martin
Site Admin
Sounds like a failing ignition switch. Note it's only the switch not the key barrel etc.
The switch is cheap enough as an OE aftermarket part (£16)
LR035359 / PRC8230  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #588246 28th Dec 2016 8:16pm
AJC
Thanks for the assistance there guys. Martin thank you for the parts numbers. I did have an incline it was the ignition switch.
I will get one ordered. Think I need a light stalk too as it doesn't always put beam lights on first time
Post #588321 28th Dec 2016 10:48pm
AJC
Martin. Those part number say to suit tdi or td4 and not td5.
Do you know if that's right?
A quick search finds me this one
https://www.ebay.co.uk/itm/291617753245
LR039638 Land Rover Defender Steering Lock Ignition Switch 200 300 TDi TD5 Puma
Post #588326 28th Dec 2016 10:57pm
Martin
Site Admin
I'm sure you've got this sorted by now but anyway
PRC8230 / LR035359 / LR039638 are all the same. There is nothing different between them, just supercession.
The only different switch was the pre-Tdi diesels which had a heavier-duty and physically bigger switch to handle the manual glow plug position.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #590063 4th Jan 2017 2:23pm
