Home > Maintenance & Modifications > heated mirrors
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
heated mirrors
Anybody installed these? i want to install mine with a timer relay and suitable switch...but what switch and where? suggestions welcome V8 90...WIP
Post #588208 28th Dec 2016 6:40pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
I recently bought a heated front screen and wiring kit from VGS. Although the screen is not fitted as yet, I fitted the wiring harness and wired the heated mirrors (had been lying in a box for over a year) into this. Stays on for about 8 minutes on the timer. You could still buy the wiring kit and just use it for your mirrors, but maybe a bit of overkill as the wiring is rated to carry much more current than the mirrors pull.
Post #588221 28th Dec 2016 7:14pm
Paulv8
hmmmmmmm yes... well i have a heated screen and i could just wire the mirrors into that i guess... not a bad shout V8 90...WIP
Post #588222 28th Dec 2016 7:16pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
I took a feed from the HRW switch to switch a relay and ran it from that. That way when i turned the HRW on the wing mirriors came on as its porbable you will need both,. Now in my 110 im planing to do the same but also use it to trigger a relay for a future HFW.
Post #588237 28th Dec 2016 7:45pm
dave18
Usefull link on running the wires Wink
http://la7dja.org/defender/mirror-heating/
Post #588239 28th Dec 2016 7:48pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Yes and are an absolute blessing, I took the power from the heated front windscreen Thumbs Up
Post #588241 28th Dec 2016 7:59pm
Romadog
Used heated screen too Thumbs Up
Post #588247 28th Dec 2016 8:16pm
Paulv8
cheers for that.exactly how i was planning the cables to go so good to know its possible. V8 90...WIP
Post #588279 28th Dec 2016 9:06pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Agree with above wireto heated front screen as already on a timer and wiring is easy to get to
Definitely worth doing though I used the mud ones fitted to back of original glass 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #588297 28th Dec 2016 9:55pm
Stacey007
Can each side be tapped into the Heated front screen without a relay or anything.
Thanks
Post #588303 28th Dec 2016 10:09pm
Paulv8
they are low power, so no reason why not V8 90...WIP
Post #588310 28th Dec 2016 10:22pm
Mo Murphy
I wouldn't wire the mirrors into the heated screen circuit for the simple reason that the screen draws a fair bit of power when running and there will be times where you just want to heat the mirrors. They draw little power so you can run them through a switch without the need for a relay. An ignition switched supply from your auxiliary fuse box will ensure you don't run the battery flat leaving them on when you switch off the ignition.
HTH
50 Shades of Pennine Grey
Post #588318 28th Dec 2016 10:32pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I wired mine to the rear heated screen and not the front screen as I don't like to keep using the front heated screen as it can burn the wires out in the screen.
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #588336 28th Dec 2016 11:31pm
JWL
Another one for not tieing the mirrors to the screen. I have mine on a seperate switch and there's quite a few times that they get used seperately such as the screen is often clear but the mirrors mist up especially on these cold misty mornings we've been having. They're great for keeping the mirrors clear when there's a lot of road spray and also in the rain, times when the screen is allready clear.
With the draw on them all I did was put a switch after a 7.5 amp fuse
Post #588345 29th Dec 2016 12:13am
Hairysteve
TBH, I have not had a need to heat the mirrors and not the front screen so meets my needs and is a simple option Whistle
Post #588562 29th Dec 2016 9:45pm
