Home > Puma (Tdci) > Puma 2.2 Coolant Change to Waterless (Evans)
ob1conobe
United Kingdom 2014 Defender 90 Puma 2.2 HT Alpine White
Hi all,
I am relatively new to this forum group. Having looked through various posts I can clearly see there is a great wealth of information from very knowledgable contributors.
So as per the post subject, I am trying to find out a little more information in regards to waterless engine coolant. I purchased a new 90 a couple of years ago and it falls out of warranty in January 2017. Recently, when checking the engine coolant level I noticed it was a little low, in addition to the fact it looked a very un-healthy brown / rusty colour. The coolant overflow bottle is annoyingly also a brown coloured plastic which also makes it a little harder to read the level easily. (In contrast my everyday VW Golf has a clear container and the coolant is a nice fluorescent pink colour). So a couple of questions in turn:
1. Is it normal for such a new vehicle (circa 24k miles) to have coolant that already looks brown / rusty?
2. Does anyone have any experience of using Evans waterless coolant specifically on my vehicle model?
3. As the vehicle will shortly be out of warranty, I want to gradually start doing service items myself. Can anyone offer advice / guide etc. regarding 2.2 TDCI draining / flushing / re-filling coolant? And in addition using Evans waterless coolant?
4. Does anyone recommend a replacement coolant expansion tank that is clear Wink
Thank you in advance,
OB1
Post #587941 27th Dec 2016 12:01pm
ROBBONTHEROCK
Scotland 2007 Defender 110 Puma 2.4 XS CSW Firenze Red
Personally I'd avoid something like waterless coolant.
It turns something that can be easily maintained into something that is a bit bespoke, for questionable improvement on a std engine.
I know that Evans is used for some people who tune engines where hotter engine temperatures are the norm and therefore need a solution.
I would just drain it, replace it with a decent concentration of the std fluid and replace it in 5 years time or so.
They do have a service interval.
Andy
Post #587946 27th Dec 2016 12:14pm
Dreamweapon
Scotland 2008 Defender 110 Puma 2.4 HT Cairns Blue
I'm also considering Evans coolant, on the basis it doesn't overheat, good to -40 and doesn't pressurize the system quite as much, so less expansion or pressure on seals, gaskets and hoses.
Post #587964 27th Dec 2016 2:37pm
I looked at Evans, as I am using a tuned 4.6 v8 in my 90, I came to the conclusion that it's basically an over hyped, expensive liquid, that's flammable.
As long as you have a healthy radiator and hoses, normal anti freeze is more than capable. QRZ 2e0vpf
Post #587965 27th Dec 2016 2:47pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
lets be real here
if your defender is having an overheating problem, something is broken..
unless your defender is a performance machine or something.....
Post #588091 28th Dec 2016 9:51am
grafty99
If waterless coolant was that good then why wouldn't manufacturers put it in from the factory? I agree that regularly replaced standard coolant and deionised water is perfectly adequate. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #588110 28th Dec 2016 10:52am
ob1conobe
Post #588190 28th Dec 2016 5:49pm
ob1conobe
Post #588224 28th Dec 2016 7:18pm
jst
we ran this 4 years ago or so on a heavily tunned td5 auto for Croatia. it worked well to help with cooling, but is a long old filling cycle to get all the water out plus its £££££££££££££ for not a lot was my conclusion.
Plus on day 5 or so when a branch took out a rear rad elbow and we lost the lot we had to drain and fill with water anyway... Big Cry Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #588292 28th Dec 2016 9:27pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Evans waterless coolant ..
Long discussion here - in a roundabout way:
https://www.aulro.com/afvb/90-110-130-defe...hoses.html
Post #588354 29th Dec 2016 6:55am
ericvv
^^ Interesting read and findings on aulro.com. So much for that idea.
Think I stick to my practice of having the standard water/antifreeze coolant mix replaced every few years. I don't like Land Rover's recommended coolant flush/replacement at 200.000KM only. Seems a bit long to me to remain assured that all anti-corrosion inhibitors and other additives in the antifreeze solution still have their full working capabilities after such high mileage.
If I remember well, in the past 8 years and 80.000 KM my coolant was replaced already twice, last time with the installation of the PEL500110 thermostat. Gives peace of mind.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #588357 29th Dec 2016 8:14am
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
Evans
GDay fellas.
I'm the person who was asking about Evans in Oz.
As per the thread, I've decided to stay with OEM coolant and regular changes. We often operate in above 40 deg c temps, and I often tow a 2 1/2 ton van, so will stay away from it.
An EGT gauge and accessory water temp gauge is high on my list of mods though.
Best wishes all.
Ken
Post #588366 29th Dec 2016 9:16am
ob1conobe
Well it's looking like the general synopsis is to stick with the conventional arrangement.
So on that basis, can anyone shed some light on the various questions raised in my original post?
Based on the rusty brown colour in my vehicle, I am keen to replace soon ...
Cheers.
Post #588431 29th Dec 2016 4:43pm
ericvv
^^ Answering your question 1, my truck is a Puma 2.4, 8 1/2 years old, 80+K km, coolant has been replaced twice by dealer, each time when installing new thermostats, but none of the coolant mixes ever really changed colour, certainly not to a rusty brown or so.
Post #588448 29th Dec 2016 5:34pm
ROBBONTHEROCK
Cheers.
The rusty brown colour, wouldn't be some sort of reaction timing of different types of antifreeze would it?
Given its rusty brown and a cause for concern, i would drain and re-fill with fresh anti-freeze and then monitor the colour for the next few months.
It might take two flushes to get rid of all the rusty coloured water though.
I would definitely check the fluid that is drained though and ensure its a not rusty looking due to some sort of oil contamination (although i would expect it to be milky if oil in the water).
Andy
Post #588494 29th Dec 2016 7:23pm
