Home > For Sale & Wanted > [For Sale] Store room clear out - lower prices !
Page 2 of 2 <12
Martin 01
Those rear door seals any good for a Td5 ?
Post #588182 28th Dec 2016 5:29pm
bob neville
They will fit a 110 TD5's rear doors, they are fitted to the door itself and the door shape/size has not changed for years.
I have fitted the fronts on my TD5 and they actually fitted better than the ones I fitted to my Puma.
Just something to be aware of, Puma or TD5, you will probably have to drill the odd mounting hole in the door as the studs on the new seals never seem to line up. I changed all the old type seals on my 2009 110 DC and had to drill one or two new holes in the bottom. You will obviously have to drill holes in the side of the door for the studs as these do not exist on TD5's or the Puma's prior to these becoming standard.
Easy job, probably an hour's work plus time for some drying if you paint the holes after drilling.
Having said that, with the LR build tolerances you may only have to drill the holes for the new side studs !
Have a read of this thread, on page four you will see my write up of fitting to a rear door.
Note the bit about Waxoyl, it WILL destroy the seal !
http://www.defender2.net/forum/topic6370.h...p;start=45
2013 Defender 90 CSW - sold
Post #588191 28th Dec 2016 5:56pm
LiftedDisco
Does the Nugget Stuff breather station also include the airlines?
Post #588296 28th Dec 2016 9:53pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Don't suppose you have a part number for the front puma style door bottom seals bob? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #588298 28th Dec 2016 9:56pm
bob neville
Front new style door seals are LR029309 - they are not handed.
The breather station does not include airline but .... measure up how much you want and I will see what I can include.
It does include connectors so you can just extend your existing breathers.
Post #588314 28th Dec 2016 10:26pm
Page 2 of 2 <12
