![]() | Home > In Car Electronics > fitting a double din stereo in a defender td5 |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 532 ![]() ![]() ![]() |
http://www.defender2.net/forum/topic47698.html
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4801 ![]() ![]() ![]() |
I'm looking into doing this.
In my opinion they sit too low in the standard dash because of the angle and depth of the switches above. To overcome this I was going to modify a spare dash so the top row of switches sit flat parallel with the face of the centre dash. This way the stereo can be installed a good 30mm higher. I do think double din is the way forwards though ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
robtd590 Member Since: 28 Dec 2016 Location: Somerset Posts: 26 ![]() ![]() ![]() |
Thanks for your help guys.
Disco_Mikey that does look a very tidy job, I would imagine that the adaptor plate isn't thick enough to be able to use counter sunk screws... as I would like to try and minimise the look of the screws. However I do appreciate that it is a defender after all and it's not unusual to see screws and bolt heads. Also like the look of what Jont has done with his double din centre dash. |
