![]() | Home > Puma (Tdci) > Defender Air Con Retrofit |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20912 ![]() ![]() |
I know Devon 4x4 has done conversions, maybe they could help you?
Out of interest, what sort of cost region did you achieve with recon parts. New kits are £2000 plus I believe exc fitting. _\Hennessey|Venom| F5/___ ___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ Last edited by custom90 on 27th Dec 2016 7:05pm. Edited 1 time in total |
Dreamweapon Member Since: 19 Dec 2016 Location: Hessische Odenwald Posts: 55 ![]() ![]() ![]() |
Thanks for the reply Steve, so far I have the following larger components, expenditure so far around 600 quid:
Condenser assembly including fan. The four main pipes, compressor - condensor, condensor - dryer, receiver - evaportator, evaporator - compressor. Compresser and cover. All bought as delivery mileage take off parts. Pulley and accessory belt (new parts). I still need the LHD Evaporator, receiver dryer, bolts, brakets connector, switch and various other bits and pieces. Luckily I can source from all over Europe to my German address and UK to my Scottish address so expect to be all in around a grand. Hope to get finished by June before it gets over 30 ![]() I'm still looking for the LHD Evaporator part no and the correct one for the receiver dryer (JRJ000020?).. |
Quite a good saying there then!
Regarding your required P/N, Dan @ Duckworth parts may be able to trace that for you and possibly even supply maybe if you were so inclined. _\Hennessey|Venom| F5/___ ___\âï¸Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
Wantatoy Member Since: 17 Sep 2016 Location: Surrey Posts: 21 ![]() ![]() |
I have fitted a few of the Elite kits which is more or less a JLR kit, I'm fairly sure that I kept the full instructions book so if needed I should be able to scan it and send by PDF / email although not till back to work early Jan.
The Elite kits can be fitted in a day if you lay off the tea breaks!!!!!!! Is there Libary type thing to hold that type of thing on the forum??? |
If you could PDF the instructions for the MY07 onwards kit that would be perfect
![]() Google drive, MS OneDrive cloud storage, or I can PM my email address. Thanks a lot |
