Home > Puma (Tdci) > Gearbox
L110CDL
Gearbox
Hi All
All you Puma drivers with the MT82 gearbox's, how do they compare to the R380 gearbox for reliability for every day use with your landy loaded unloaded etc.........I have read that you have to change one of the shaft's as this is a design fault Rolling Eyes
The reason for me asking is they now do a adaptor plate for the MT82 to fit a Tdi engine Very Happy
Thank you for all your answers in advance Clayton.
Keeper.
Post #587825 26th Dec 2016 10:20pm
grafty99
Having had vehicles with both the MT82 and the R380 the MT82 definitely changes more consistently and once run in mine changed very sweetly. The shaft failing is the adapter shaft between the gearbox and transfer box. If properly lubricated on installation then it shouldn't give trouble Thumbs Up
I personally can't really see an advantage to fitting one, however, as apart from having a very low 1st the gear ratios are pretty similar and 6th is actually very similar ratio to R380 5th 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #587845 26th Dec 2016 11:03pm
grafty99
In fact my Td5 with disco V8 5th and puma transfer box revs lower in top than my puma did Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #587848 26th Dec 2016 11:06pm
L110CDL
Many thanks for the info grafty99 Thumbs Up Clayton.
Keeper.
Post #587849 26th Dec 2016 11:06pm
shaggydog
I can remember Ashcrofts doing a thing about it and they concluded it would not work very well in a Tdi, the ratios are all very set to the Puma engine and the Tdi would struggle a bit as its much lower revving.
If it was me I would spend your money on a Rocky Mountain Overdrive instead which would give you basicaly a 6th gear but at much less cost and hassle plus all your existing gears are left in place.
I have been driving a Puma for a couple of weeks now and find the gearbox is a bit Signal Boxy compared to my Lt77. The R380 I had in Miss Shaggydogs Td5 was definitely better then both.
Just my opinion amongst many others Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #587930 27th Dec 2016 11:16am
Owning both, I have no hesitation at all in saying that I think the MT82 is incomparably better in every respect to the R380. The latter is in my view one of the most second-rate gearboxes of recent times and a huge disappointment.
That being said the installation of the MT82 in the Defender leaves a lot to be desired, in fact every engineering aspect of the fitment of the Ford engine and 'box is very shoddily done.
The MT82 as used in the Defender is unlikely to be remotely suitable for use with other Defender engines due to the ratios it contains. It may be that other versions of the 'box are better suited, it is after all used in a range of vehicles most of which probably don't have the world's lowest first gear.
Post #587940 27th Dec 2016 11:56am
L110CDL
Thank you Shaggydog for your info, very interesting as i forgot all about the overdrive Thumbs Up
I have been following your thread on your SHB landy Very Happy Clayton.
Keeper.
Post #588027 27th Dec 2016 9:09pm
L110CDL
Thank you Blackwolf for your reply, food for thought Thumbs Up Clayton.
Keeper.
Post #588028 27th Dec 2016 9:11pm
JOW240725
Not driven the R380 box for a very long time so can't compare, but the MT82 box is my least favourite thing about the Puma. I feel you have to be very gentle with it, changing gear slowly and even letting it neutral between a 1st and 2nd to change smoothly. If you treat it nicely it does pull well and cruises effortlessly at 70+ Whistle James
Instagram @suffolk_rovers
Post #588039 27th Dec 2016 10:04pm
I like the MT82.
The adapter shafts should have been lubed from the factory, some weren't.
Mine was okay, but still waswirth checking once in.
My only criticism is 1st gear is ever so slightly too low.
If you need really low gearing low range does that.
When pulling away into traffic quickly you have a very rapid change up required.
Some do so in 2nd from a standstill, I never do and never had unless in motion.
Never driven an R380 to comment, but all in all I like it. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #588047 27th Dec 2016 10:18pm
jockobite
110 stuck in first gear, lever in neutral
Hello, new to here and already looking for advice ! I've a 110 (10 plate) and it has stuck in i think first gear, but the gear lever is in neutral. I've been trying to follow similar threads on here but my question is, are the two indented plugs almost hidden by the gear lever mount bracket? can anyone show me a pic of them? if so can i unbolt the gear lever and get better access to the vertical plug? and is it ok to drill into it and lever it out?. then whats next? Any advice would be very much appreciated, thank you kindly
Post #588049 27th Dec 2016 10:34pm
Dieselhead
Never had a problem with my MT82. I treat it with care.
1st gear is great for pulling away with heavy loads & 6th is great for motorway work Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #588087 28th Dec 2016 9:20am
L110CDL
Many thanks to you all for your knowledge and outcomes of the gearbox Thumbs Up Clayton.
Keeper.
Post #588339 28th Dec 2016 11:38pm
John65
My feelings are much the same. The change isn't as good as it was on my old 200tdi with the LT177 box. However I gradually got used to it and now I don't see it as a serious issue. I'm currently half way through a 9 week lay off from driving due to a hip replacement, so it will be interesting to see how long it takes me to get the changes going sweetly again when I re-start.
As others have said first is very low, so you soon need to change up to second once you move away. However the low ratio could be useful if you are towing a heavy load.
John
Post #591350 8th Jan 2017 7:24pm
