![]() | Home > Td5 > MAF sensor |
simon67 Member Since: 18 Jun 2015 Location: west sussex Posts: 569 ![]() ![]() ![]() |
Yes you can run it but it will be lumpy
On a brighter note I have a brand new one sitting in my office Duckworths do them for £120, yours for £100 including P&P |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 ![]() ![]() ![]() |
Thank you for your kind offer, but will be ordering from BAS
https://secure.bellautoservices.co.uk/store/td5-air-flow-meter/ Edward |
Happy do it for £80 including p&p
jrule Member Since: 10 Aug 2015 Location: Hertfordshire Posts: 302 ![]() ![]() ![]() |
Simon I'd be interested if not
Jrule, if ews doesn't want it, it's yours
Still boxed and ready to go |
Loz2286 Member Since: 31 Aug 2015 Location: High Wycombe Posts: 121 ![]() ![]() |
Can I have second dibs? 1999 Td5 110 CSW
1961 Series 2 88 LPG |
Just st waiting on EWS
Hi Simon.
Let it go, thanks for the kind offer. Edward |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2066 ![]() ![]() ![]() |
All, apologies for the resurrection....
Hope you had a nice Christmas. Did you sort it EWS? Picking up on this info: https://secure.bellautoservices.co.uk/store/td5-air-flow-meter/ The diagram suggests testing for the approx 2vdc idling output at Pin 3 whilst the text states Pin 2. Can anyone please confirm? ![]() Happy New Year to one and all. |
Hi Screbble.
Still running with MAF unpluged, have not noticed any problems, drives like it should . Have a cheapo one in the spares box just have not got round to fitting it, will purchase a VDO one in the next day or so. Just pull the plug and tuck it away and run with out it, you should notice the difference, in my case it was an . amazing increase in performance. Pin 2 is the feed out and pin 3 the ground, so I understand. I pushed dress making pins through the insulation to get a reading, to clip on the voltmeter. Somewhere on here is a post from Dorsetsmith, explaining the workings , seen it today but cant seem to find it again. Edward Edit Just found it, look down this post, read Dorsetsmiths post, good reading http://www.defender2.net/forum/topic41695....maf+sensor |
