Home > Td5 > new fuel pump,cleand out harness now running s**t...help |
You wouldn't see any leaks if the injector seals have gone as they leak into the engine but your oil may be rising with the diesel in it Ray
22nd Dec 2016 7:29pm |
22nd Dec 2016 7:58pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Thanks I new somebody would reply quickly. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
22nd Dec 2016 8:09pm |
also on early fuel filter heads td5 had none return valve fitted they can jammed closed stopping fuel flow
22nd Dec 2016 9:13pm |
psimpson7 Member Since: 20 Nov 2013 Location: Gold Coast, Qld. Posts: 221 |
Also check to see you dont have 2 seals on the fuel filter. sometimes the one from the old filter sticks on the housing and then the filter doesn't seal properly and allows air into the system 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top. 2014 90 XS SW 2.2. |
22nd Dec 2016 11:43pm |
lozza Member Since: 13 Oct 2016 Location: oxfordshire Posts: 190 |
morning,will do those other checks and let you know
loz |
23rd Dec 2016 11:57am |
latest,it is starting ok but when you press the throttle its very hesitant untill full throttle then it revs,fuel line disconected at filter ignition on fuel flows great,when the engine is running the filter gets hot to hot to touch,new filter same thing,i am thinking regulator,just been down the bypass at 70 deffo not right not the smooth td5 more lumpy and filter roasting after 2 mile run
reading the manual regulator seems to be the one ,before i buy a hawkeye diagnostic would it show the regulator as a fault or is it a visit to a dealer thanks loz |
26th Dec 2016 3:43pm |
NO
26th Dec 2016 4:11pm |
no as in?
26th Dec 2016 4:12pm |
Click image to enlarge are you refereeing to item 13 ? |
26th Dec 2016 4:16pm |
i buy a hawkeye diagnostic would it show the regulator as a fault |
26th Dec 2016 4:17pm |
i am referring to 13
26th Dec 2016 4:24pm |
thanks |
26th Dec 2016 4:26pm |
is it normal for the filter to get as hot as say a real hot coffee you have to put down
26th Dec 2016 4:27pm |
