![]() | Home > Puma (Tdci) > How to undo the belt tensioner? |
| o4dn Member Since: 08 Jan 2010 Location: South West Posts: 602
Ah nevermind, I managed to undo it... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864
1/2 square drive extension and bar through the 1/2" hole IIRC
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
^^ 3/8" maybe? Solved the bowel problem, working on the consonants...
You could be correct - I think I used a 1/2 bar for leverage with a 3/8 adapter on the end......
Yeah pretty sure that's it
I knew there was a reason i bought an adaptor, but for the life of me couldn't remember why the other day! Solved the bowel problem, working on the consonants... |
" it is
Maybe there are different castings/parts?
I'm now 99% sure mine is 3/8", check the sticky in this forum re. serpentine belt change. Solved the bowel problem, working on the consonants... |
Yeap, you're absolutely right of course, I used the 3/8" adapter that I found in the torque wrench box... My bad!
Sorry for the confusion! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
| Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 |
I used a large pair of stilsons
2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
| All times are GMT |
