Home > Technical > LT230 transfer box refurbishment. - bush left over on the be
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi
I changed all bearings and seals in my MY 2012 transfer box and fitted an Ashcroft diff,
When I was ready a 16mm bush was left over on the bench... Grrrrr...
Where is it situated? Thought at first at a selector shaft, but it is to small to sleeve over.
Post #586455 20th Dec 2016 12:17am
Fifth Horseman
It could be a locating dowel. Parts 2, 25 or 26.
Post #586492 20th Dec 2016 9:38am
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
Looks like 25 as its missing in the top picture NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #586497 20th Dec 2016 10:43am
TopQ1967
Thank you. Will check. Think you are right. Luckily not within the transfer box! Smile
Post #586570 20th Dec 2016 5:41pm
Alien
Australia
If it's not for there compare the size against the intermidiate shaft.
Some housings flog out where the "0" rings sit, there is modification where a bush/sleave is inserted.
This requires the casing to be drilled/machined and the bush pressed in Cheers,
Kyle.
Post #586655 20th Dec 2016 11:54pm
Post #587165 23rd Dec 2016 1:00pm
TopQ1967
It was the bush Kyle segmented! 😏
Post #587321 24th Dec 2016 12:37am
