![]() | Home > Puma (Tdci) > Tdci running rough and cutting out. |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Are all of your glow plugs all working
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
If the engine started may be the glow plugs are OK,
IMHO a little be of Diesel paraffine due to the below zero T°, Are you using artic fuel (Diesel with additives for low temps). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
The only reason i thinking glow plugs is that my pickup had same problem and it turnout to be two glow plugs not working replaced them and next cold start -12c not problem
| mobilesawmiller Member Since: 03 Mar 2013 Location: Co,Tyrone Posts: 100
Thanks for the information lads. I will look at the glow plugs and my diesel. Have a good Christmas.
