![]() | Home > Puma (Tdci) > Hot hand brake |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 ![]() ![]() ![]() |
Definately not the case on mine, I would notice when I wear shorts, as I am sure, like everyone myleg sits against the handbrake lever.
I would get it checked again! |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Not on mine also Eduardo
MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
dave's 110 Member Since: 11 Jun 2008 Location: Norfolk Posts: 45 ![]() ![]() ![]() |
Hi Stephan
that a look at my other post on this on here http://www.defender2.net/forum/topic360.html?highlight= Dave |
Stephan Member Since: 13 Nov 2008 Location: Windhoek Posts: 12 ![]() ![]() ![]() |
Hi Dave,
Thanks for the info. I will check with my dealer tomorow. Stephan Meiring II - 130 Puma 2008 Meiring I - 110 200TDI 1989/1991 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8372 ![]() ![]() ![]() |
only when the heater is on 'feet' and set hot and fan on 3! Cheers
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Yep, also had it on mine,, long Motorway run, after 30.40 mins,,
Try it with the window closed,, with it open, the air/heat get dragged up through the seat box !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Bundubasher Member Since: 25 Sep 2008 Location: Sandton Posts: 34 ![]() ![]() ![]() |
Hello Stephan. The same thing happened to me when I drove to Kruger park in october. I was a bit concerned at first but the next day it was cool when I was driving around the park. I think the problem that we both have is that our roads radiate so much heat in summer and when we drive at a high speed the heat radiates from the hot road surface and the whole transmission system gets so hot that the heat eventually radiates to the hand brake lever etc. I hope this helps.
Regards Anthony |
Hi stephan
Yes happened to me whilst coming back form the Alps . Popped the seals on the transfer box too. Look at my last post here http://www.defender2.net/forum/topic784-15.html |
Dundubasher,
Thanks. I do think there is something to do with heat (road or ambient) I have seen that if the ambient temperature is below 25 C then the hand break does not heat up. Not sure if it is radiant heat or expensiontion and tolerance playing up. Stephan Stephan Meiring II - 130 Puma 2008 Meiring I - 110 200TDI 1989/1991 |
