![]() | Home > Technical > 2013 110 Clutch |
| Tumbiri Member Since: 01 Nov 2016 Location: Caribbean Posts: 53
Thanks!
Do you have a PN for the latest clutch? My Defender is a 2013 Puma 2.2L. |
I buy all my parts on-line from Rimmer Bros.
Thought I'd update the thread with the findings.
In the end it came down to a disintegrating pilot bearing in the flywheel. Took the opportunity to renew the clutch assembly, slave cylinder/release bearing, slave cylinder adapter and valve. Sometime ago the gearbox was dropped to get to an oil leak. Suspect that on reassembly the clutch assembly may not have been aligned correctly and was the ultimate cause of the bearing failure. Any comments? After everything was put back I found that the gear shift lever would not freely move to the neutral position when coming out of second to go into third. Also more vibration than normal is being felt in the gear lever. It freed up after a while and with the engine running the lever would center. However, with the engine off the lever will not center on its own. Any ideas what may be causing this? |
| agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324
Could just be the 'whatzit' that holds down the lever ball joint itself. Take off the boot and have a look, 4 bolts.. you should figure it out
(Why oh why does it have 4 bolts instead of 3 that's another question...) Solved the bowel problem, working on the consonants... |
