![]() | Home > For Sale & Wanted > [For Sale] Pair of 90 axles, Radius Arms,Trailing Arms,Props |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243 ![]() ![]() ![]() |
I have a surplus pair of 90 axles. These have come from an early 90 but I believe the rear axle is from a later vehicle as it is disc braked.
The brakes functioned fine before they were removed, swivels look in reasonable condition, think the rear diff pinion seal is leaking. Come complete with brakes hubs etc. Both axles disc braked, the rear axle half shafts are the (10spline) one piece with mushroom drive members. Diffs turn freely. The rear axle has a new diff pan welded on. Diff oils are partially drained out but was clean and likely changed recently. Vehicle mileage was 120k from memory. £75 each I also have a pair of the earlier narrow radius arms from the same vehicle, assume bushes need replacement £30 Also a pair of trailing arms, same condition as above £25 Also got a pair of props from the same vehicle (LT77 box) Rear one seems okay, front one needs a new UJ I believe £25 the pair £200 for all of the above combined, collection from Sheffield (near Meadowhall). Open to sensible offers. Also willing to do swaps/px with td5 90 props, series style doors, td5/tdci front wing and rear body wiring looms etc which I am in need of. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
Bump, still available, open to offers.....
Prop shafts provisionally sold and rear calipers sold.
Pair of axles now £75 Trailing Arms £25/pr Radius Arms £25/pr Steve 02' 110 TD5 Double Cab Rebuild Thread |
Offers before they go on ebay? 02' 110 TD5 Double Cab Rebuild Thread
dgravedigger Member Since: 03 May 2016 Location: Gozo Posts: 45 ![]() ![]() ![]() |
are the axles still for sale? do you have pics of them please?
Axles are still available.
Only have a picture of the front at the moment ![]() Click image to enlarge Will get one of the rear tomorrow if you want? Cheers 02' 110 TD5 Double Cab Rebuild Thread |
I am mostly interested in the rear axle, can you get me some pics of it when you have time please?
All still available except for the prop shafts....
Happy to separate the axles up and sell the parts separately. In which case there are two 10 spline diffs, early hubs, one piece 10 spline rear shafts, early CVs and halfshafts etc 02' 110 TD5 Double Cab Rebuild Thread |
