Home > Maintenance & Modifications > county interior
Procta
county interior
can anyone give me the heads up on what I need to kit out my landy in county interior. At the moment its very van like and it would love to make it more nicer inside.
I am sure the puma has some fancy rear plastics? Anyone can shed some light on that?
Got to start looking at blinking up the procta defender!
Post #585083 14th Dec 2016 7:26pm
Morepower
New Zealand
The std puma 90HT even in XS Spec like mine has nothing in the back... (well apart from a black headlining)... I had to spec a rear load mat and the sides had nothing, Although I did get some speaker mounts in the corners... The 110 USW on the other hand had rear window surrounds and side covers.. (although I had to buy some TGE inserts)... although again I had to add a load cover in the back...
Hope that helps..
Tim It doesn't matter how bad it is, It can always get worse...
2013 Bowler 110 (Sold)
2016 Bowler 90 Rally Spec (Sold)
Post #585104 14th Dec 2016 8:51pm
Procta
cheers, what models had the full spec in the back?
Post #585123 14th Dec 2016 9:34pm
Riverboy
2014 Defender 90 Puma 2.2 SW Corris Grey
My 90 SW as it was when I first saw it and as it left the factory. It seemed to have it all really. Head lining, side linings, carpet, rear seats etc etc. Its an export model so I have no idea if they were different to UK models. I don't know what they call the county spec over here Question
Post #585132 14th Dec 2016 9:43pm
Procta
That's what I want to have! Is there a full blown kit for kitting out a landy, I know the seats you can buy, Its the interior trims and carpets I am after.
Post #585143 14th Dec 2016 10:05pm
Morepower
New Zealand
you can buy the carpet for the rear... I bought it for the 110 from landrover and made my own sides
Post #585147 14th Dec 2016 10:14pm
mk1collector
I think simmonites do a copy rear plastics kit for window surrounds etc and a full roof lining would probably brighten it up a bit which you can get on eBay or maybe Lri solutions (site sponsor) Ray
My build thread
Post #585156 14th Dec 2016 10:36pm
Retroanaconda
There are no factory trims for the rear sides of 90 hard tops, they were all bare. Station wagons had trims, but also windows/seats/carpets etc.
I have used a set of 90 SW rear trims to fit out the back of my 90 HT.
The rest is just carpets/headlining, fairly simple.
Post #585161 14th Dec 2016 10:45pm
Procta
I like that! How much did that set you back?
Post #585334 15th Dec 2016 5:03pm
Retroanaconda
The trims were c. £150 - they go for silly money second hand. Headlinings were a few quid from local breakers.
Carpet etc. was cheap from one of the big carpet shops. Got the end of a roll.
Post #585535 16th Dec 2016 10:30am
Procta
I will be looking at kitting mine out with in a decent budget, What place is the best of headlining? I have speakers in mine, so I want to keep them there, I am not faffing on moving wires and drilling dashes.
Post #585655 16th Dec 2016 8:38pm
VeeTee
Netherlands
La Salle Trim does headlinings and trim. I do not have personal experience with them, but it seems good quality... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #585662 16th Dec 2016 9:07pm
RichLech
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
These side panels are a great fit, help stop drumming noise and protect the thin aluminium sides.
http://www.mudstuff.co.uk/mud-90-side-panels.html
Post #585668 16th Dec 2016 9:25pm
Procta
only thing with the headlining is I have speakers up there, I have seen one which looks like it has a radio slot built into it, I am just after a plain one like I have already, I am wanting to fit a roof console from mud at some point, just for the extra storage.
Post #585842 17th Dec 2016 7:10pm
mk1collector
If you just have the front section of head lining you should be able to buy the rear section seperately and as I said simonnites do a rear plastic trim kit Ray
My build thread
Post #585887 17th Dec 2016 9:29pm
