Home > Maintenance & Modifications > fitting sump/steering guard
pom
Just got one, any have a fitting guide?
thanks
Pom
Post #58493 11th Feb 2011 4:45pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Pom, there really easy i fitted one Rolling with laughter Rolling with laughter just put the brackets on first and then the plate 30 mins max Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #58495 11th Feb 2011 4:53pm
pom
ok Thumbs Up
Pom
Post #58497 11th Feb 2011 5:00pm
fekete
When you match the brackets up you will see what bolts you have to undo there are only 4 Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #58498 11th Feb 2011 5:03pm
pom
well i got 3 big bolts with the guard, is there a 4th already on the chassis somewhere ?
Pom
Post #58500 11th Feb 2011 5:10pm
18stone
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
From my TD5 days the 4th bolt was through the tie-down loop/chassis rail?? D300 HSE 110
Post #58501 11th Feb 2011 5:12pm
BigMike
Pom
Yes. just put it together loosely and offer it up and you ll see the bolt that's already there. its easier to put it together than put the side plates on then put on the base plate, because if you dont put the base plate on first its a Censored to get round and hold the nuts in place unless the vehicle is on a ramp. yes it makes it a bit unwieldy but one you get it hanging off the back fixings its easy
Post #58504 11th Feb 2011 5:28pm
Martin90
United Arab Emirates 2009 Defender 90 Puma 2.4 SW Stornoway Grey
Pom,
The bolt that you re-use is the chassis bracket for the panhard rod.
I put the two side brackets on first and then lifted the plate up but as stated was a bit tricky, but doable. If you do it this way, do not tighten the brackets to the chassis until you get the plate on as you need a bit of "wiggle" to get the holes in the plate lined up! Martin
1989 90 - Truck cab, Mazda 35 SLTi engine
2009 90 - Station Wagon
Post #58573 12th Feb 2011 5:39am
leeds
Dependent on the steering guard you may have to undo the steering dampner and thread one side piece over it. If there is a 75-100mm hole in one side that is what you need to do
HTH
Brendan
Post #58576 12th Feb 2011 8:31am
pom
uh oh, first problem. There is a doo dah (i dont do mechanicing)in the way.
Here is where it needs to go, the doo dah is up tight against the chassis no way to slide the clamp behind it ?
Pom
Post #58596 12th Feb 2011 10:31am
landy andy
I think the brack for the guard goes on the inside of the chassis, not the out side where the "Doo Dah" is
Andy
Post #58599 12th Feb 2011 10:45am
landy andy
Post #58600 12th Feb 2011 10:47am
pom
leaving it for the grease monkey. i was guessing it wouldn't be a straight forward job!!
Pom
Post #58601 12th Feb 2011 10:47am
landy andy
It is simple I just think you are putting the wrong side bracket on the outside of the chassis instead of the inside. You just need to undo the bolt through the "doo dah" slip on the guard bracket and do bolt back up. (After you have removed tie down eyes from chassis)
But I am sensing you have had enough Whistle
Andy
Post #58602 12th Feb 2011 10:53am
pom
yeah you could be right!
Post #58603 12th Feb 2011 11:31am
