Home > In Car Electronics > Dash bulbs
Procta
Dash bulbs
Hi fellas, what are the best ones to buy to upgrade the clocks lighting? Mine and my dads are very weak.
Post #584806 13th Dec 2016 5:42pm
What engine / year? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #584809 13th Dec 2016 5:44pm
Procta
One landy is a 1994 the other is a 1997/1998, Basically 200 tdi and a 300 tdi Thumbs Up
Post #584824 13th Dec 2016 6:30pm
dorsetsmith
if you can not find right ones i have used this below
Post #584856 13th Dec 2016 8:11pm
jr1104
United Kingdom 1998 Defender 90 300 Tdi CSW Rioja Red
Just fitted a set of LED bulbs from Fourby.co.uk to my 300TDI. Has definitely helped with the brightness, and the blue colour is more legible than the dull green.
From the way way the light shines around the dials though, I'm not sure it'll ever be as bright as a modern car. All you can really do is make the edges of the dials get brighter!
Post #585397 15th Dec 2016 9:03pm
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Not sure if you can replace the clock bulb, normally sealed? I put the blue LEDs in the other dials and it is an improvement. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #585574 16th Dec 2016 2:46pm
jr1104
I replaced the clock bulb when doing mine. It's a different type of bulb, but was as easy to change as the rest of them.
Post #585625 16th Dec 2016 6:48pm
