Home > Maintenance & Modifications > Defender tdciDOOR HANDLE HELP!!!
arran jones
Hello all,
I have a defender 90 TDCI 2009, and the driver side door handle(on the outside) is very wobbly, any ideas of how to sort this
I was thinking I might need to take the inside of the door off the reach the back of the handle to tighten up the screws but I don't know weather that's the right thing to do or not, just need to get it fixed b4 it properly comes off!!!
Anyone help that's knows or have had the same problem would be very much appreciated
Many thanks Very Happy
Post #584135 11th Dec 2016 5:33pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
As long as the screws are not rusted up your plan is the best answer.
I can't remember if you can get to the handle screws without removing the metal panel behind the door trim that holds the window winder mechanism. So the job might take longer than you think.
Make sure you have spare plastic clips for putting the door trim back on as they always break.
Post #584140 11th Dec 2016 5:51pm
ickle
If you have manual windows, don't forget the tip from this forum about using a duster and a sawing motion behind the handle to release the clip Thumbs Up
Post #584143 11th Dec 2016 5:55pm
mk1collector
Yes you will need to remove the door trim but I think the metal bonded in fixing in the handle itself will have let go meaning you will need a new handle. Ray
My build thread
Post #584144 11th Dec 2016 5:57pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
Here's a diagram of the location of the screw. marked as 5
 Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #584148 11th Dec 2016 6:03pm
arran jones
Cool,
Thanks all for the great help Thumbs Up
Post #584170 11th Dec 2016 7:23pm
Stacey007
Hello
Passenger side on mine did this, almost as if it was going to pull off in hand...
I took the door card off to fit the silent coat and it was literally a screw to tighten it and job done Smile just be careful taking the door card off you try not to snap the plastic lugs off.
I thought it would be a pain but an easy job Smile
Post #584178 11th Dec 2016 7:40pm
arran jones
Just in case the defender door card clips do snap off, would these be the right ones??
http://www.lrparts.net/mxc1800-defender-do...is-no.html
If not, does anyone know where to get the right clips from??
Many thanks
AJones
Post #584297 11th Dec 2016 10:54pm
Stacey007
They look right
Pretty certain on mine if they clip off you can re fasten them on Smile
Could be worth having some spare at that price but 50....
If you want to split I would be happy to but 10 to keep spare.
Post #584313 11th Dec 2016 11:05pm
LR90XS2011
My post from about 18 months ago
loose door handles Report post
A couple of months ago 1 of the screws fell out of my drivers door handle, today I noticed that the passengers side one was loose. So this is a warning to all, if you notice your door handle is loose tighten the screws before they fall out.
the fix
tools = philips screw driver, torx t20 driver, trim tools or suitable alternative, 2mm pin or equivalent
1/ remove the door closer handle (philips screw driver)
2/ remove the door release handle back plate (philips screw driver)
3/ push the pins into the two trim clips at diagonal opposite corners of the door, (do not push them right through)
4/ pull the door card off carefully it has fir tree type clips top, bottom and rear edge, work it around the door release handle and door lock plunger
5/ Poke a hole through the foam and plastic sheet in line with the door handle screws and then tighten them
6/ I then smeared silicone sealant on the screw heads/door panel to stop them coming undone again.
7/ tape over the 2 holes
refit is reverse of removal, guide the door panel over the release lever and lock plunger and the cable guide rubber
note it is much easier to do this before the screw has fallen right out, if it (they) have fallen right out recovering them from the bottom of the door generally involved the use of a magnet, or damage to the foam door liner .
total time 30 mins per side DEFENDER 90 TDCI XS,
Post #584349 12th Dec 2016 7:19am
arran jones
But I don't know weather that's the whole set and weather it's for a tdci or not,
I saw these ones aswell, do these look right???
http://www.yrm-metal-solutions.co.uk/Land-...stener-Kit
Many thanks
Post #584366 12th Dec 2016 9:07am
Cupboard
I'd be very interested to know what you do get in the end, my driver's door handle has been wobbly since I bought the Defender 2 years ago and I've been putting off taking the door car off.
Post #584388 12th Dec 2016 11:21am
agentmulder
Kuwait
FWIW, I've fixed leaks on the drivers front, lock on the front passenger, noise on the mid passenger and unmounted the wheel on the rear. Never had an issue with the clips...
Not sure what, if anything, I'm doing right though! Go figure? Solved the bowel problem, working on the consonants...
Post #584390 12th Dec 2016 11:28am
Scotm
Arran
The white bits in the YRM link are fitted in the door frame. They are usually ok and don't ever need replacing.
The 2 larger black bits are fitted to opposite corners in each door and usually reusable if you don't loose the middle bits.
The smaller black bits are the ones that can break. They fix between the door card and the white bits in the frame.
Post #584401 12th Dec 2016 12:28pm
Unfortunately, more often than not, it's the feeble plastic bit that holds the black peg to the door card that breaks rather than the black peg itself. This can be very difficult or impossible to repair, although if it is a thick part of the card a suitable countersunk head wood screw can be screwed into the card and the peg attached to the head.
After removing and refitting these door cards many times, the two things I always do to preserve the clips are (1) always use a trim removal tool so that the pegs are pulled out as straight as possible and the leverage is applied right by the peg, and (2) lubricate the pegs with either silicone polish or Vaseline before refitting.
If you have a 4-door Defender with central locking you need to get good at this job because you'll be doing it annually to fix the wiring!
If you lose the peg from the expanding plugs an offcut of fence wire can be used as a replacement peg.
Post #584413 12th Dec 2016 1:03pm
