![]() | Home > Puma (Tdci) > Recall |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18031
Wow, that is an old problem, mine was done in 2010 as a service item. I wonder what's happened to make it a recall.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
^^^^ Same as BW here too, and the seatbelt bolts one. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363
No such recent recall according to DVSA. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
| stigomery Member Since: 10 May 2016 Location: Cambridge Posts: 277
I thought all defenders did this
| YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1648
You had me all excited thinking it was going to be to replace the output shaft!!
The problem LR identified was supposedly specific to the TDCi, in which the engine and gearbox are tilted up at the front to allow the engine to clear the front axle. This raises the oil level at the rear of the transfer box with the result that the rear output shaft oil seal becomes more susceptible to failure. That at any rate is the theory, but I have to admit that from an engineering perspective it always sounded a slightly flimsy theory (given that it is not unknown for people to drive up hills, park on hills, etc., in earlier models). |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
How were you notified?
Can you post up whatever paperwork you got? |
| RFT Member Since: 13 Nov 2010 Location: Yorkshire Dales Posts: 695
This was done at a service on my 2010 MY a good few years ago 130 Puma HCPU with an Artica 240LR Demountable Camper
I wasn't notified.
I took the Defender in for a main dealer service (not long after the warranty had expired) and asked them to sort out the oil that was running out of the handbrake drum whilst they were doing the service. It was a pleasant and unexpected surprise afterwards to be told that there was no charge for the oil leak repair since it was a service action for a known problem. If I hadn't taken it for a dealer service, I'd never have known. There was a couple of other known problems that they dealt with at the same time, one was the replacement sump pan (the early 2.4s had a sump which the axle could impact on full articulation, usually with catastrophic results since all the sump oil was ejected), but I can't remember at the moment what the other was. These were all three examples of LR's rather hooky way of dealing with these matters, namely they'll do it free of charge but only if you ask them to. It's a crafty and arguably cynical way of minimising their liability, because they only repair (a precentage of) the vehicles which actually need repairing. If they recall them, they repair them all. Last edited by blackwolf on 9th Dec 2016 4:31pm. Edited 1 time in total |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
Service actions are not recalls.
Service actions are only done if the customer reports the fault, otherwise the fault doesnt exist "if it aint broke and all" Recalls are notified to the last owner on the books Mike |
| ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637
Hi,
So a service action would still be up to LR to action FOC, assuming we identify the issue and point it out to the dealer directly saying it is an issue? Cheers Andy |
In theory, yes, but you may have to be quite persuasive.
And im surprised they did it so easily for you so long after the fact - ive known them to say no to that too! Mike
Sorry blackwolf - I should have made it clear my post was aimed at at the OP... |
