Home > For Sale & Wanted > [For Sale] Thatcham approved bullock pedal lock. " SOLD
Sulisuli
Bullock antitheft device made from steel. Comes with 1 security key £50.00 plus carriage.
Locks the pedals, fitted in seconds, carbonitride steel resistant to cutting, drilling, and torsion forces.
Thatcham approved.
In the Auto Express tests it took 17mins and 5 secs before the thief could overcome the security. which gave it the top points in the test.
Most thieves will have given up within 2 minutes and the added advantage is that because the system works on the brake and clutch pedal it's very difficult for a thief to get any purchase on it, he would need to be kneeling down beside the car to get to work on it, which eliminates all but the most ambitious criminals. Even he would need the right tools and enough time to work on it.
This is from the article:
"Extremely well made, the Bullock withstood massive and sustained attacks without budging.
It's strength, plus ease of fitting and competitive price, make it a worthy winner." 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #580746 27th Nov 2016 10:06am
gcc130
Yes please, PM sent.
Post #580763 27th Nov 2016 12:52pm
Sulisuli
PM replied too. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #580765 27th Nov 2016 1:21pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Hi,
does this fit on a Defender? Also, is it able to lock brake + throttle? I think clutch + brake won't be enough.
cheers
Frank
Post #583256 7th Dec 2016 5:00pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
No, it only blocks brake and clutch, but I don't see the issue f you put the car in gear and the handbrake on.
I've one and once you're used to it, it's installed in less than 10 seconds. But you need to do it properly and make sure it is fully closed, otherwise it might open. Give it a good shake and a push toward the floor. I have also noticed that it locks a bit more easily when slighty tilted to the left, it probably depends on the pedal adjustment.
You'll need to adjust the length of the lock with a setscrew so it doesn't allow downward movement.
Mine is the X-model as the Bullock website suggests, but several members of the Belgian club have the L-type. Usually I store it underneath the passenger seat, you can just slide it underneath snugly with only the handle sticking out without annoying the passenger.
As far as the 17 minutes are concerned: apparently it does have a weakness, which iIl presume will be known by professional car thieves. And since a defender is quite high, one is not awkwardly bent that low when trying to sabotage it.
Regards,
Joris
Post #583281 7th Dec 2016 7:06pm
Vogler
Also like to add that it comes with two keys when new.
J
Post #583282 7th Dec 2016 7:08pm
macfrank
I guess it's better than nothing. However, you can shift gears without using the clutch, so throttle (and handbrake) is all you need...
Post #583292 7th Dec 2016 7:56pm
gcc130
I've used one of these for many years on my series one runabout. They are so easy to use I put it on every time I park up, even if it's only to nip into the paper shop.
It may be possible to drive away without clutch and brakes, but it certainly wouldn't be easy.
When parked at home or for longer periods I use additional security measures.
You will never stop determined thieves, but if I can slow them down or make them look for an easier target all the better.
Post #583436 8th Dec 2016 10:45am
pjb
Anything is better than nothing Thumbs Up
Easier to store than the standard pedal lock I have Thumbs Up 2020 P300 HSE
Post #583442 8th Dec 2016 11:18am
