Home > Maintenance & Modifications > Heated seat loom
isacs
Heated seat loom
Finally now upgrading to heated seats, I'm planning on going oem. Has anybody used the mobilecenter loom?
http://www.mobilecentre.co.uk/index.php?ma...ddec05cb75
Other option is the FCX variant at £100 more??
http://www.fcx.co.uk/_p/prd1/2620831381/product/heated-seat-loom.
Anybody used either? Plus is it another dash out job for the switches and associated wiring?
Greg
Post #577319 12th Nov 2016 5:34pm
Defender marto
United Kingdom 2004 Defender 90 Td5 HT Oslo Blue
I used the mobile centre loom and it is ok. But I got the one that only had the plug for the switche as I sourced the seat plugs myself, and I got my switches of eBay though. £25 for the 2. They where of a disco and the right orientation to but I could only find them in black but that did not bother me.
Post #577324 12th Nov 2016 5:45pm
isacs
So brought the loom from FCX, arrived today and fitted this evening. Very well made piece of kit, really was worth paying the extra.
Post #580240 24th Nov 2016 10:27pm
jst
what do you get for the extra? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #580248 24th Nov 2016 10:45pm
isacs
Its all plug and play, no cutting no splicing. 2 relays go under the drivers seat, taking power from the fuse board in there. All cables are in convoluted tube, all with factory plugs on. Centre console out to piggy back the hazard button to give the switches and relays switched live and illumination, then correct left and right hand seat buttons with black and green molex plugs, another wire then down behind the fuse board (Td5) and join up to the harness under the seat again. There's a PDF on the FCX website (not viewable by mobile device) with full instructions, albeit puma but everything else is the same.
Took me about 2 hours in the dark just using a lead lamp.
Post #580257 24th Nov 2016 11:03pm
jst
Cheers Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #580324 25th Nov 2016 9:30am
FCX loom here too, very good. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #580341 25th Nov 2016 11:05am
Chopperone
Slight hijack of thread: Mazda rx8 seats
Any idea as to which of these wiring looms would be best to use for Mazda seats OR am I better off making my own?
Thanks
Guy
Post #582994 6th Dec 2016 6:04am
geobloke
Just bought the MC loom (last night as it happens). These early dark morning dog walks have prioritised the warmth... Happy wife, happy...
Post #583011 6th Dec 2016 8:54am
isacs
Re: Slight hijack of thread: Mazda rx8 seats
Thanks
Guy
Without seeing the connectors for the Mazda seats i wouldn't want to pass comment. Though I'm guessing they are just 2 wires?
Post #583145 6th Dec 2016 10:06pm
dgardel
Italy
If you can, do it yourself (as I done) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #583172 7th Dec 2016 12:27am
Chopperone
Which loom did you buy & what is your vehicle?
Guy
Post #584038 11th Dec 2016 10:14am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Copied form another thread I posted to;
I've only wired my drivers seat at the moment (passengers can just have cold bums). I wired both the motor/movement and heat to the same relay. Essentially, using a common earth and live. It's working on an ignition live to an illuminated switch by my hazards. I was lucky enough to get the male AND female connector for the seats too. This all goes back to my auxiliary fuse box with adequate fuse. My plan was to fit the relay with others in my ECU seat box...
So as you can work out, I have to switch the heat on to make any seat adjustments, but that doesn't happen too often and is only for a few seconds when needed. Originally, when wired separately, I was finding the seat moving on it's own as the door card was interfering with the switches.
I have since tidied the wiring and used heatshrink etc.*
PIN OUTS
Seat Motion
Grey - 12v
Purple - Ground
Lumbar
Yellow with Red trace - 12v
White with Yellow trace - Ground
Heat
Blue - 12v
Passenger Seat Heat
Red - 12v
Black - Ground
* I'm lying. This was one of those quick jobs to 'see if it works' before doing a proper job. It's on the list... TD5 Defender 90
Discovery 3 HSE
Post #584405 12th Dec 2016 12:42pm
geobloke
Guy
Hi Guy. Apologies I did not see this question. I bought the MC simple loom without switches. The switches I got of eBay for £30 from a Disco and in grey so the dash still looks proper. The seats (half leather items from a TDCI) work a treat, heat up quickly and I have to say is really fabulous on a cold damp morning. Wish I had done this mod years ago...
If anyone would like photos I am happy to put some up.
Cheers, Guy Thumbs Up
Post #594366 19th Jan 2017 12:27pm
