![]() | Home > Puma (Tdci) > Engine warm up and Temperature gauge position |
| Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 926
I would think that it is A) actually doing that so maybe the thermostat is sticking slightly open and hence the extended warm up and then cool off OR B) the gauge isn't right and indicating wrongly possible electrical fault?
Even on the few cold days we had after the gauge would climb to the centre in about 10 miles and stay there regardless to up or down hill driving, the heater will gradual increase heat in line with the gauge. IMHO after the 10 miles and ~ 10 mins I have to turn it down or i'll roast. Similar setup to you with the 2.2 with an alive tune with the EGR off. |
| mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109
Mines nice and warm in circa 3 miles at 30 mph
| apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547
With the last few days of frosty mornings, mine has been taking about 15 mins of typical town driving to warm up. Even then it has been reluctant go the very last bit on the needle (ie to bang on mid may) and the air is not quite the usual scolding. It hasn't really gone the last bit till getting onto a dual carriageway.
I had been wondering whether that is normal or not. Seems a bit too long? |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
Thanks for the info Devon Rover think I will change the thermostat and see what difference that makes, I don't think it's an electrical fault on the temperature gauge as it's too consistent in the way it behaves with regard to where it climbs too and then drops back too and the time taken each time this happens.
Any other thoughts ideas or suggestions gratefully received 2008 SVX 90 2000 XS TD5 90 |
| ChrisJ Member Since: 12 Nov 2013 Location: Warwickshire Posts: 231
My 2105 takes a good 5 miles worth of driving on a 50mph road to get the needle to Half way, my needle also drops if I'm sat still for a while, I put this down to the fan constantly running.
How long have you had it? ie was it the same a week or two ago when it was warmer outside? (op)
Yes been like it since I picked it up on November 1st. So it's not just the cold weather that causes it. 2015 HT XS 90
| Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1876
Just had the same issue with mine. Dealer diagnosed it as a faulty thermostat, swapped and now back to the usual furnace like setting
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Thanks Rosco appreciate the reply, think I will have a chat with the main dealer tomorrow, did you have it done under warranty out of interest? PEL500110 thermostat is this the preferred option? 2015 HT XS 90
All under warranty. No mention of which thermostat they've fitted though 2007 - Stornoway Grey 90 XS SW - Gone
Excellent news will try the warranty approach with them thanks. 2015 HT XS 90
| Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196
Hi,
Interesting ! Seems approx the same as for my def 2.2 from 2012 except that this is comming after 4 years and 117000km. Changing the thermostat did change nothing. I will reed the comments with interest Phil I would like to say that it seems to be ok know Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 Last edited by Phil VM2.5 on 13th Dec 2016 8:53pm. Edited 1 time in total |
| xpertoftheseas Member Since: 05 Jan 2016 Location: Salisbury, Wilts Posts: 164
Same with mine.... Even after 30 mins of driving mine will sometimes only just get one quarter of the way, and if we hit standstill traffic it plunges back into the blue with no hot air at all.
It is in now for some failing paint work and they are looking at it. Only 18months old... My 10th Land Rover, but my first Defender. |
Mines now booked in for the thermostat on Tuesday next week, if it has failed its warranty claim if not it it about £250.00!! Fingers crossed it's failed
