![]() | Home > Maintenance & Modifications > TUNING / ALIVE/BAS REMAPS |
NCTT Member Since: 07 Apr 2008 Location: ESSEX Posts: 229 ![]() ![]() |
right peeps , ok im pretty useless with techy stuff and having looked at the bas/alive remaps the ones you control yourself with the box i need to know HOW easy is it ?
ok it looks easy but im pretty poor with a compuer, i use an imac , anyone else done it with one and how easy is it ? my other question then is ive got a 4 month old puma and if i get it remaped by a tuner , i.e non switchable will the dealer know when it goes in for a service ? |
Do what TC says otherwise this will all go Pete Tong again.....what i will say what ever Map you get its easy to install and the supplier will help you with any difficulty's
ok will do cheers fellas
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8367 ![]() ![]() ![]() |
i dealer wont know in the first instance and wont bother checking it unless there is an issue engine warranty wise and they think it may have been mapped, they can then send the ecu away to be checked.
what they could do though is overwrite your upgrade and you cant get it back. i would get a switchable one and reset it prior to going back to the dealers. Some dealers do remaps anyway but just dont advertise them. interface is very easy to use on a PC. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
Plus if you're using a more recent imac, you can run the (Windows) software on Parallels or Bootcamp.
HTH, ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
![]() ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
The pressure of responsibility.........
