Home > Puma (Tdci) > What if anything did I do wrong?
Page 2 of 2 <12
JBC
Thanks JLW that's helpful to know. I was starting to think that this sort of shelter really isn't meant to move but is made to look like it can be to get round planning laws.
I have some big screws to replace the nails in the frames which just pulled apart. Most of the wood is still ok but there's a few featheredge boards that splintered, so not too bad all things considered! Sue even saw the funny side of it after a while!
Jon
Post #582287 2nd Dec 2016 10:00pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
JBC wrote:
Well thanks for all your advice. I followed it to the letter and got traction!
Unfortunately the field shelter maintained its traction too.
The defender moved forward about 15m with the front end of the field shelter. The rest stayed where it was. I now have a large pile of firewood! Oops. I have a rebuild project on my hands. Any advice on that too?!
Er, um, well that wasn't supposed to happen Shocked Not quite sure what to say.
Whistle Dave
Green Goddess - 1998 Defender 110 300tdi
Post #582289 2nd Dec 2016 10:26pm
Rashers
I suppose it was better than the rear end falling off you Defender?
And you won't go cold this winter with all that fire wood you now have.
I just feel for the horse Shocked
Post #582301 2nd Dec 2016 11:21pm
VVS210
As already said, when I move ours I go round with a bar & pry each end of both runners out of the ground first to make sure they aren't dug in & to make sure the structure is still sound. Ours is built on metal skids & can be hooked up with an A frame although I prefer a pair of straps & D shackles. Use low box & no diff lock but the 90 is wearing XZLs Very Happy
Post #582302 2nd Dec 2016 11:25pm
JOW240725
Sorry it did make me chuckle. Lucky the front of the shelter didn't end up through the back window! Rolling with laughter James
Instagram @suffolk_rovers
Post #582305 2nd Dec 2016 11:49pm
JBC
Well that was my comment to Sue! "Thank goodness it didn't hit Dorris!" Sue said "look at my shelter!!!" "Oh. Yes. It's bad isn't it? I can fix it!" Says I. It took a while before we laughed....but we did in the end. It's only a shelter after all. Any way. I now know what I'm doing twixtmas...
Post #582310 3rd Dec 2016 12:06am
DAZ110
It had to end this way didn't it ?, when you think about it! Rolling with laughter
Post #582315 3rd Dec 2016 12:55am
DSC-off
jst wrote:
DSC-off wrote:
Traction Control on a Defender only works on the rear axle, not all 4 wheels
really? where did you find that out from?
My mistake, the OP's defender should indeed have TC on front and rear axles. Embarassed
Around 10 years ago I had a TD5 XS, and was told by a mechanic that it had rear axle only TC, the same as some RRC and early P38s upto 1998. Apparently the later P38s and all Disco2 had TC front and rear.
I don't know for sure if the TD5 Defender was rear only, or if so when it changed to F & R.
Would be interested to find out if anyone knows.
Post #582317 3rd Dec 2016 1:51am
JWL
The Td5 uses the ABS system sensors in "reverse" i.e. when the wheel, any wheel, spins faster than the limit then the modulator applies pulses of the brake on that particular wheel.
So it's not just limited to any one axle. This set up can only work for short periods as the pulsing generates heat in the modulator block and a safety factor that's built into the ECM shuts off the function. This can be a little disconcerting to you as a driver because if you're three parts of the way through a tricky loose surfaced hill climb the traction control will cut off leaving you unable to get the grip you require. You give up, depress the clutch so you can get reverse gear engaged to control your descent and at the same time the clutch goes down you realise that the brake pedal is solid and won't depress! Gravity takes over in the blink of an eye and usually before you have selected reverse and you become a passenger on a rapid return in the direction you have come from!
No matter how much you frantically keep trying the brake pedal, nothing will happen untill it's ready, underpants can be soiled in this short time Whistle
I'm sure I read somewhere that the modulator block can be operating the application of the brakes at something like twenty times per second or it might be the time line of the sensors sending signals to the ECM.
Post #582318 3rd Dec 2016 2:11am
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
Off topic ...
Some very useful replies here.
Slightly off topic: in mud, snow or especially deep sand - if traction is the same poor quality for all 4 wheels - i.e. no real difference for TC to detect and act upon - there wouldn't be any benefit then? (not calling upon "airing down" here)
Would TC in this case be more of a hindrance - i.e. trying and braking and thus actually hindering momentum?
Better then to switch it off - if possible?
Anyone here with experience of DSC - as per 2014 on Defenders? Manual describes it is better to switch DSC off in above circumstances - but must admit I haven't tried it yet.
Also - DSC equipped Defenders: does the TC warning light actually illuminate when TC in action - in my vehicle definitely not - only shows up when ignition is switched on. But I can feel & hear TC working.
Thanks !!
Post #582321 3rd Dec 2016 5:47am
mse
All the sand and snow ive driven in ive turned DSC/TC off - its always felt better that way Mike
Post #582375 3rd Dec 2016 12:48pm
nosnibod
The sensor in a DSC-equipped Defender is intended to detect side loading vs steering angle. As far as I can tell as well as instructing the ABS to brake different wheels it will also cut engine power. That works well on-road, but this is a Land Rover, so...
Off-road there may be situations where you don't want the power to be reduced; for example in a hill-climb using a bit of speed and momentum. If things get a bit shaky - for example going over bumps etc - then the DSC might cut the power.
So the general rule is to turn off the DSC if you need to power over or up something. Otherwise just leave it enabled. Dave
Post #582414 3rd Dec 2016 4:16pm
Sadi
Thank you all.
Will give it a try.
Was hoping to get some info whilst doing a LR Experience day - but only available in South Africa - but unavailable during the year end vacation.
Post #582562 4th Dec 2016 6:29am
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
JBC, your plight with the shelter reminded me of this.
Kiwi Toyoty Pickup ad.. Rolling with laughter
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #582565 4th Dec 2016 7:17am
JBC
Post #582582 4th Dec 2016 9:31am
Page 2 of 2 <12
