![]() | Home > Technical > Squeaky brakes!!! |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 736 ![]() ![]() ![]() |
So, pads have arrived, whipped the wheel off and old mintex pads out. Go to put the new genuine pads with shims in only to find they won't fit!!!! They're the same shape as the mintex pads and have no doubt that there right but they're too thick even without the shims, the abrasive material is about 1.5mm too thick!!
![]() So now I can only assume that the disc is the issue here as that's mintex as well, just a bit too thick, so looks like I'll have to change to genuine discs too now at £50 each!! ![]() |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
Rear pads come in two thicknesses, from memory 15mm and 17.5mm
Looks like I've got the latter then, buggar
mata Member Since: 24 Jan 2014 Location: Manchester Posts: 153 ![]() ![]() ![]() |
Reviving an old thread here. I think forums are at there best when the solution to problems are posted on the ends of threads. I start all my fault finding by googling and reading threads on various forums for my various cars but i couldn't find any posts where people have come back with definitive solutions to squeaky rear brakes.
Like many i've been putting up with squeaky back brakes since a local 'specialist' put some mintex pads in the back of my 2009 110 Utility. I wont go into the boring customer dissatisfaction story but will say that having tried and failed to cure the problem with copaslip on the back of the pads, then balking at the £62 for genuine LR pads i just tried chamfering off the leading edge of the pads with an angle grinder (i actually took quite a bit of material away - 45 degrees grind almost righ down to the backing). Only a short road test thus far but this appears, for now, to have cured the problem and i can now brake the car without gritting my teeth. I'll come back after some more miles with an update. |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
105k on the original discs with various pads fitted no issues at all 😎 Get all new discs pads and front calipers and now I've got a front squeal when low pressure braking annoying
