Home > In Car Electronics > Installing rear interior light in 2.2 90 HT
CarMan
I bought a rear headlining at the Stoneleigh show from Phil at OEM and of course it has a hole in it for the interior light which I have now ordered and am happy to use as a dummy to plug the hole, but would be better if I could make it work.
I'm assuming I will also need the mounting bracket VUU500440?
There is a switch in the rear and it is wired, but what would I need to do to connect to the new light in the headlining?
Can't find it from a search but assume there might be a loom as there appears to be for the front one.
Please no technical wiring drawing, as I will not understand them Confused Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #581651 30th Nov 2016 4:18pm
JOW240725
Complete electrical numpty here but... does the front interior light come on with the rear door? If so can't you just wire in series to the front one? James
Instagram @suffolk_rovers
Post #581659 30th Nov 2016 4:49pm
CarMan
Ditto. Good question and I should have said - but no it doesn't, so thanks for prompting me to clarify.
Post #581665 30th Nov 2016 5:14pm
Cupboard
The front light should come on with the rear door...
And you mean in parallel. If you wire them in series then each one will get 6V (nominally).
Post #581667 30th Nov 2016 5:32pm
CarMan
Aaaarg Embarassed it does! Forgot I turned it off due to the glowing led issue, sorry.
But, the question still remains how are they 'factory' wired?
Post #581670 30th Nov 2016 5:36pm
JOW240725
See I knew I shouldn't have commented Embarassed Just didn't want you to think your post was being ignored Confused James
Post #581675 30th Nov 2016 5:47pm
When I fitted a second interior Mud LED light over the second row seats in my DC, I simply connected it in parallel to the exisiting front row Mud LED light, so each of the three terminals is connected to the same terminal of the other light.
This means that they come on together from the AS10 (ie unlock, engine off, and door opening) and can be switched individually between AS10, OFF, and ON. Simple, and works a treat.
Post #581679 30th Nov 2016 5:56pm
CarMan
Ok, sounds good, thanks. I had assumed there may be an off the shelf loom, but please advise to do a proper job what wire and connectors I should be looking to get Rolling Eyes
Thanks.
Post #581685 30th Nov 2016 6:04pm
JWL
I added a third interior light in my 110 SW, I put one over the second row seats in addition to the one by the interior mirror and one at the very back in the cargo area. I was finding the second row seats were very dark and the extra light is very welcome. All that I did was to tap into the wires that were allready above the roof lining going from front to back. I am using leds with no hassle.
Post #581781 30th Nov 2016 10:19pm
Cupboard
I'd use crimp splices myself. Quick, easy, good joints.
Post #581921 1st Dec 2016 2:01pm
