Home > Puma (Tdci) > 11MY Puma Steering "Splines"
BruceT
South Africa
Hi All,
Doies anyone know how many splines the Puma has for its steering wheel.
I am looking at ordering a steering wheel and steering wheel boss online.
Thank you
Post #57906 9th Feb 2011 8:28am
BigMike
They vary. Some have 36, some 48. Only way to be sure is to take the wheel off and count them.
Post #57931 9th Feb 2011 10:09am
BruceT
South Africa
OK thank you.
Post #57932 9th Feb 2011 10:12am
Naks
Indeed, you need to count the splines manually. I had to go through this to get the right boss for mine. --
Post #58051 9th Feb 2011 5:41pm
Merlin
Do you really need a steering wheel puller, to get it off?
Merlin
Post #58091 9th Feb 2011 7:32pm
BigMike
no, but dont take the nut off, just unwind it until its *nearly* off. if you take it off you are likely to pop the wheel off and smack yourself in the face as it needs a lot of leverage. take it from someone who knows Laughing
Post #58092 9th Feb 2011 7:33pm
Merlin
I’ve been struggling with it all afternoon and it’s beaten me.
Post #58095 9th Feb 2011 7:37pm
BigMike
do you have a pry bar?
Post #58097 9th Feb 2011 7:37pm
markb110
http://www.mudstuff.co.uk/shop/71-moto-lit...-boss.html
Some information here that may be of help
Mark
Post #58099 9th Feb 2011 7:39pm
Merlin
I stuck some tyre levers under it but it just bent.
Post #58100 9th Feb 2011 7:40pm
Naks
You need a 22 socket to take the nut off. And then you need to pull very hard to get the steering wheel off, most likely you will smack yourself in the face with it Rolling with laughter --
Post #58125 9th Feb 2011 8:32pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Embarassed Embarassed Embarassed NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #58136 9th Feb 2011 9:05pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Tr this.
Make a fist and with your right hand bang the right hand side of the wheel then do the same with you left hand and on the left hand side of the wheel. repeat and get faster. It does work if you have not got a puller.
Post #58142 9th Feb 2011 9:33pm
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
A steering wheel puller is a super cheap tool but if you are too lazy to buy one, take a small metal bar and drill two small holes in it exactly inline with the holes on the wheel ( one on each side of the big nut). Lay the metal bar over the center bolt and screw two screws equally in each hole until you are pulling the wheel off the splines. Not sure if I wrote it correctly but works the same way as a crank puller on a bicycle.
Post #58183 9th Feb 2011 11:45pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I recently removed the steering wheel from my MY11 XS as it wasn't quite straight when driving straight (was 1 spline out, which was annoying me), and what I found was a bit unexpected.
You cannot use conventional puller tools as suggested above as the two holes either side of the large centre nut are no longer centred about it at 9 and 3 oclock, if you see what I mean. They are now at roughly 7:30 and 4:30. Also, they don't seem to be threaded any more either and are now blind. I checked with an M8 bolt (the two holes are about 8mm dia) and it it just pushed in until it bottomed out in the hole.
Fortunately, I loosened the nut a few turns in preparation for giving it a proper battering, and is popped loose with nothing more than a few seconds of gentle rocking.
Pete
Post #58278 10th Feb 2011 3:17pm
