![]() | Home > Puma (Tdci) > Help ID these Sensors |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
They're to do with th dpf. One is a pressure sensor and on a temperature sensor.
The pressure sensor is to sense the pressure difference between pre and post dpf so it knows when it's getting blocked and needs to do a regeneration. The temp sensors make sure it doesn't get too hot during th regeneration and also that its hot enough to begin one. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
big110 Member Since: 02 Nov 2016 Location: Pinner Posts: 396 ![]() ![]() ![]() |
Roy- dpf?
Diesel particulate filter.
Like a catalytic converter but worse as it clogs up then sets its self on fire to turn the carbon into ash. Annoying but a legal requirement in many countries. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
