Home > My Defender > 130 - Tow machine
Page 5 of 11 <123 456 ... 91011>
L110CDL
Hope this helps Rosco Whistle Clayton.
Keeper.
Post #580973 27th Nov 2016 11:34pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #580981 27th Nov 2016 11:47pm
Red8eard
2003 Defender 130 Other HCPU Chawton White
Rosco wrote:
Looking amazing this build. Looking forward to hearing how it performs on and off the road.
Red8eard wrote:
I also fitted some sound deadening and completed the bonnet work.
Is that the Britpart bonnet kit?
Yes it is,
Cheers guys, The trans tunnel will be something like that with a curved "roof" i think. Got to have the box for the isolater and incorporate some sunglass and phone storage, ill probably make some wee boxs or steal them from antoher car.
How do you embed videos on this board btw?
Cheers,
Ged
Post #580982 27th Nov 2016 11:55pm
L110CDL
Good to see some different mock ups on the tunnel Ged Thumbs Up As for the tube i just copy and pasted it on, the tube info is under the tube in a oblong box Thumbs Up Clayton.
Keeper.
Post #580984 28th Nov 2016 12:00am
mcma1
do you sleep mate!! serious speed you get through this stuff Thumbs Up Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #581065 28th Nov 2016 1:03pm
excossack
How does the Td5 engine & R380 box compare in dimensions and weight to the Cummins and ZF box? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #581079 28th Nov 2016 2:29pm
Red8eard
I sleep a little. just have to keep making a list and stroking it out. Then make a new one. one step at a time. Typical Armagh man just bull on lol.
Whole package is around 200kg heavier than the td5. But the Cummins makes 450nm of torque... at idle lol more than the td5 at full chat. So its defiantly more gutsy than the td5 but does lack the revs so 1.1003 tbox helps along with a 3k+governor spring.
Post #581095 28th Nov 2016 3:48pm
Red8eard
Had a big push there over the weekend and ill break it into 2 parts, first the front end, now together will light guards and air con grille fitted.
@mcma1 kindly donated some light guards which needed a wee touch up and paint before going onto the 130, really like the look of them.
Put some foam on the back to stop them scratching and rattling on the wings
I had to make a plate at the top to make the aircon grille fit a non aircon wagon. rivenutted the original then added the bracket and drilled
then 2 lower brackets out of some angle and rivenuts in the wings
Then drill and rivenut the lightguards onto the wings
Threw the grille on just for now ill have to get something sorted as it badly cracked, might make something.
Couldnt have turned out better in my opinion, got some tired bits to replace like the grille but im loving the clean but slightly modded look thats actually hiding a monster vision ive had is coming together.
-Ged
Post #582478 3rd Dec 2016 8:24pm
Red8eard
Been working away on the trans tunnel. I found an old tunnel in the shed, sliced it in half and added around 100mm in the middle with some aluminium angle keeping the OEM look.
I took the standard closure plate for the bulkhead and gave it a similar treatment.
Test fitting
Then fabricating a cover plate for the large hole out of some aluminum plate.
Get the hole cut and seal and rivet it up job should be a good one.
-Ged
Post #582821 5th Dec 2016 11:09am
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Are you using a standard transmission gaiter? Working towards Carry on camping!
Post #582944 5th Dec 2016 9:28pm
L110CDL
No need for any mock ups for the tunnel there Ged, that looks great and nearly oem Thumbs Up Clayton.
Keeper.
Post #583334 7th Dec 2016 10:07pm
Red8eard
Its getting there. bit of finishing work to do with the isolater switch box and lever hole but should work nicely.
It will be a universal gaiter of some sort. as im controlling difflock and hi/lo with air cylinders
Got some badges and bits in the post so i couldnt resist a little photoshoot.
really should be working at her but i needed a play lol
Post #583604 9th Dec 2016 12:11am
L110CDL
lol i know what you mean Wink you will able to take the corners faster with the suspension like that Rolling with laughter Clayton.
Keeper.
Post #583963 10th Dec 2016 10:16pm
Leviathan
Awesome build.............. but I cant help noticing the Samuel Denison test machine in your workshop. I'm intrigued how come its there. Does it work?
Post #583994 11th Dec 2016 12:07am
Red8eard
Hehe cheers lads,
Yea the test machine works, its a friend of mines handy for proving out designs etc. Im an engineer by trade so theres always something cooking about the place. Most people comment on the gardner generator setup.
Heres a wee video for you all i took when i took the previous pics.
Going to have to make an intake for the compressor next queiten down the put put put
-Ged
Post #584007 11th Dec 2016 2:12am
