Home > Technical > New Nas Rear Step Advise on rusting!!
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Been wanting one of these for ever!! So decided to bite the bullet and treat myself it's about time I've not spent a penny on my P&J for ages (I've spent a small fortune on my new boat over the summer though... Laughing )
I've heard that these Nas Rear Steps suffer from rusting under the rubber tread plate as it's a water trap!? Has anybody else experienced this? Is there any way of stopping it before I fit it there must be something I can coat it with over the powder Coating to stop the rusting??? 2010 Defender 90 HT
The longer I live..... The better I was!
Post #580964 27th Nov 2016 11:19pm
JOW240725
Could give it a coat of Buzzweld CIO before it's fitted to give it another layer of protection? James
Instagram @suffolk_rovers
Post #580969 27th Nov 2016 11:24pm
Butchers Boy
Thanks Jow Thumbs Up
Guess I could spray it with Wax Oil under the rubber matting... 2010 Defender 90 HT
Post #580980 27th Nov 2016 11:46pm
Sulisuli
Will still rust, had two both rusted even with treatment, annoying but it didnt stop me having a second one and to be fair both lasted for 6 years Very Happy so go for it and just think at least it will corrode in line with the rest of the defender Very Happy 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #580983 27th Nov 2016 11:57pm
Butchers Boy
^^ Laughing ^^ Thumbs Up 2010 Defender 90 HT
Post #580987 28th Nov 2016 12:03am
Sulisuli
Nice dials in your hardtop very smart. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #580990 28th Nov 2016 12:07am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I had one fitted to my last 90, when it went in for a MOT they found it had rusted so removed it and found that the rear cross member had a rusted area which corresponded to the outline of the step, the step had only been fitted for 18 months. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #581072 28th Nov 2016 1:56pm
Shorty53
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
This was mine a few weeks after my third dealer fit replacement step. Removed the step and
tipped out a litre of brown water. I have resolved the problem by drilling small drain holes at the lowest part of the tubes. Also, lift the rubber tread regularly and look out for rust on the welded top plate joints.
Post #581099 28th Nov 2016 4:03pm
JOW240725
I should have perhaps elaborated on my advice... I've just bought a new refurbished front bumper which has been re-powder coated. I wanted to stop similar early corrosion so made an enquiry to Craig Jones (Buzzweld) who is regularly on FB and he recommended giving it a light sand to provide a key and then use the Buzzweld CIO which will provide much better resistance to corrosion. So, its really like adding was wax oil, like you said, but should be better and has a hard satin finish.
Having not done it yet, I can't comment how well it works, but it seems to be getting great reviews on FB. Thumbs Up James
Post #581103 28th Nov 2016 4:19pm
Butchers Boy
Thanks Jow I'll order some! :thumbsup
Ordered! Prevention has got to be better than cure! Very Happy 2010 Defender 90 HT
Post #581104 28th Nov 2016 4:22pm
JOW240725
Just a suggestion, I've no connection, just what I'm going to try. Just be aware postage is almost as much as the product (due to hazardous product apparently) so make sure you order enough. I now wish I'd order enough to do my bumperettes and cross member.
Just for reference if it bare metal or already corroded I think you need to put the Buzzweld RCP primer on first. Best to speak with them, they're really helpful. Thumbs Up James
Post #581107 28th Nov 2016 4:31pm
Butchers Boy
^^Thanks I've ordered two cans anyway^^^ Thumbs Up
Thanks Shorty for the tip on drilling the holes at the lowest part Thumbs Up 2010 Defender 90 HT
Post #581109 28th Nov 2016 4:35pm
leeds
If you want it not too rust, take it to a decent hot dipped galvaniser and get it dipped in molten zinc.
With holes drilled it will also coat the inside.
Then you can get it powder coated/painted to a colour of your choice.
If the top coat is damaged then it will not rust. If the galvanisation is damaged then it can self heal.
Brendan
Post #581153 28th Nov 2016 7:42pm
Mine before warranty replacement.
Post #581202 28th Nov 2016 10:35pm
Post #581203 28th Nov 2016 10:36pm
