Home > Off Topic > Wksp Heaters, diesel type
jst
i am looking in to heaters for the wksp, started looking at the diesel fired blown air ones. any one recommendations for specifics or these or is LPG etc a better option? looking for around 30kw output. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #580251 24th Nov 2016 10:47pm
walfy
Will gas fired heaters not cause condensation? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #580252 24th Nov 2016 10:49pm
Cupboard
We've got a 30 year old Thermobile at work, they're still pretty much the same (and you can get parts for the old ones).
It runs on waste oil and just does its thing. This time of year it's lit at 7AM and then runs all day.
The only thing is the regs are changing for them (think it's just for waste ones) in the spring so we're going to be getting rid of it. We've got loads of spare waste heat on site anyway and some machinery that uses waste oil for a sort of total loss lubrication system, so we're changing how we heat the workshop.
Direct heating with any fuel will cause condensation unless you're piping the combustion products outside.
A diesel burner should work fine on heating oil too, so you should be able to use whatever is cheaper out of red diesel and heating oil. Our waste oil burner (because it's a bit ancient) struggles on pure diesel because it's too thin, so we have to run at least 50% gloopy stuff.
Edit: and I'd stay clear of LPG. Per kWh it's more expensive and you're tied to the supplier that owns your tank (if you're buying bulk gas anyway). It is a little simpler and cleaner but not worth it IMO.
Post #580310 25th Nov 2016 8:32am
