Home > Puma (Tdci) > Oil spray |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2109 |
Hi Diffbeer Probably brake vacuum pump. Several of us had the same problem. Regards Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
26th Dec 2008 9:16pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2271 |
^^^^^^^what he said
27th Dec 2008 3:57pm |
diffbeer Member Since: 18 Nov 2008 Location: Farnborough Posts: 44 |
SPOT ON EDUARDO et all !
Vacuum pump , landrover assist recovered my Puma . Ready to collect today |
30th Dec 2008 11:15am |
Petrovich Member Since: 24 Jan 2008 Location: Sankt-Peterburg Posts: 75 |
Technical Service Bulletin
No.LTB00177 09 October 2008 Subject/Concern: Brake Vacuum Pump Seal Oil Leak Models: Defender (LD) 2.4L Diesel Only 2.4L Diesel Only VIN-range: 7A732615 Onwards Markets: All Section: 206-07 Summary: Oil leaking from the brake vacuum pump front oil seal. Cause: Dirt ingress into the pump pulley seal resulting in damage to the lip and subsequent oil leakage (the new brake vacuum pump has a secondary dirt lip seal). Suggested Customer Concern Code - R31. Action: Should a customer express concern, install a new brake vacuum pump (refer to Global Technical Reference GTR Workshop Manual, section 206-07 (70.15.19)). Parts Required: Description Part Number Quantity Brake vacuum pump LR012183 1 Gasket LR004381 1 Labour Time: Operation Description Operation No. Time Install a new brake vacuum pump 70.15.19 0.7 hours Repair/Claim Coding: Causal Part: LR012183 ACES Condition Code: 42 Defender 110 '07 |
1st Jan 2009 12:08pm |
