Home > Puma (Tdci) > Indicator problem |
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 |
Have you got a towbar fitted?
Does it sound like the alarm you get when indicating to remind you that you have a trailer? If so it could be a dodgy install of the wiring for the towbar. |
24th Dec 2008 7:02pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
sounds likes a short or bad earth. 2.4 90 XS
27th Dec 2008 10:54am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
THe things I'd be ticking off are:
If you have a trailer socket check it for a short Check all the bulbs for corrosion Reseat the relay Dash light staying on indicates a non-functional bulb, as its intermittent I'd also be suspecting a short somewhere or a dodgy contact being made. Seeing how the car behind didn't notice anything I'd start with Trailer socket wiring and rear bulb. 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
27th Dec 2008 1:35pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 800 |
Thanks for the pointers - I have a tow socket and I did a bit of wading a few weeks back which may have coincided with the problem - on initial inspection it is looking a bit wet and corroded, so I'll start there...
Thanks. |
29th Dec 2008 1:24pm |
