Home > In Car Electronics > Heated Front Screen - Diamondback Bison
Lund
United Kingdom 2003 Defender 90 Td5 PU Caledonian Blue
Hi all,
I have purchased and fitted a heated screen and also a front heated screen wiring kit with OEM button; it's the Red Bison Diamodback kit for my TD5 Defender.
Just a quick question in regards to the +12v source. I don't think there's enough length of wire to reach the battery box or alternator. However, would I be able to direct the feed to the starter solenoid through the O/S bulkhead or is their anything suffice that'll be closer?
Didn't spot any obvious earthing points behind the centre console either unless I'm missing something?
Thanks
Lund
Post #579094 19th Nov 2016 11:09pm
dorsetsmith
heated front screen main fuse
fuse 36 centre fuse box td5 30amp 2002 onwards
control fuse 15 5 amp centre fuse box
NO earth point in the centre fuse box earth point K108 in engine bay behind coolant expiation tank next one driver side box 6mm stud
if you have TD5 1999 to 2002 with no A/C fitted
fuse 9 or 10 centre fuse box is for ac power and fuse 7 can be used control supply will have wiring to it as also supply rear heated window
best i can do with no age or model type
Post #579134 20th Nov 2016 10:05am
Lund
All sorted thank you. In short; the wire's I didn't think would reach - did reach!
PS. This is an aftermarket kit,and doesn't utilize the original wiring/fuses.
Thanks
Post #579412 21st Nov 2016 1:12pm
