Home > Puma (Tdci) > Aux Light - The answer
mse
For those who have/wanted/thought about/may need - here is the definitive Aux Light circuit using correct switch to fit the dash.
The Switch, to give Aux 2 is part number: YUG 000540LNF (about �7 from a dealer)
Its pin arrangements are:
Pin 1 - Relay Switch (earth side)
Pin 2 - Illumination for switch (piggy back on Red Orange of other switch)
Pin 3 - NOT USED
Pin 4 - The Switches Earth
Pin 5 - Red "On" light
You can find this here
(can pdf if you want)
You need to run Pin 1's wire to the relay at Pin 86 of the relay (earth side this switched not +ve)
Pin 87 of the relay feeds the lights AND pin 5 of the Aux Switch when the lights are on.
Although i havent any spotlights yet - i have tested this and it works lighting up a temporary light.
Parts used are:
Genuine Switch, Genuine Black Connector and inserts
Standard Relay
Wire
Check your radio code...and prepare for it not to work anyway Big Cry
You can also see the genuine aux wiring kit (cost �100+ from LR) on the tech documents from landrover.com
Then you get this (sorry its a little blurred)
 Mike
Post #6125 9th Jan 2009 6:45pm
BruceT
South Africa
Hi.
Can this switch be used for a rear work light as an on/off switch with ignition off (i.e. dirct power feed from battery)?
(sorry I am technically challenged when it comes to this sort of thing.)
Thank you.
Post #57903 9th Feb 2011 8:22am
leeds
AYes you can.
That is the switch we use to operate two led lights used for reversing and camping.
Brendan
Post #57905 9th Feb 2011 8:28am
BruceT
South Africa
Perfect. Thank you.
Post #57907 9th Feb 2011 8:30am
mse
BruceT wrote:
Hi.
Thank you.
Not direclty powered from the battery without a relay in the loop. (switch therefore controls the relay)
But yes it can swtich on/off anything - but these are not designed for full loads (as i understand) and nor would you want them to. Mike
Post #57911 9th Feb 2011 8:46am
leeds
The advantage of LED over halogen!
Brendan
Post #57914 9th Feb 2011 9:10am
BruceT
South Africa
Ok thank you. Now I am confused.... Very Happy
Basically my application is a rear LED work light that has a on/off switch built into it. I would like to be able to also switch the light on/off from inside the cab for reversing at night etc.
Is there an alternate switch I could use?
Also I believe there is a fused wire behind the righ rear speaker panel which I could use. Is this continual power regardless of ignition position? Can I adapt this to be used in conjuction with the above switch?
Thank you.
Post #57918 9th Feb 2011 9:23am
Grockle
it's a latching switch so you use it for the work light and thanks Mike for the diagram etc Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #57919 9th Feb 2011 9:28am
mse
Brendan
Although i missed the LED bit originally
I still dont think i would run it through the switch direct, even if it was just ease of cabling!
What does a LED lamp pull (save me walking to the ones i have in a box)...a relay needs no more than 1 amp Mike
Post #57921 9th Feb 2011 9:43am
BruceT
South Africa
OK. So what is the best/easiest way to connect up the rear LED work light with a switch in the front? (doesnt have to be this switch)
Thank you.
Post #57922 9th Feb 2011 9:45am
mse
Thank you.
Well its all above (ignore Leeds and my discussion)
You either have power at the back and use that...therefore you are best using the switch to trigger a relay (keep main power run down) as per this thread.
Or
You have power at the front (eg battery) and you run from battery through switch to light (i dont like this option for many reasons and wouldnt recommend it)
Or
You have the power at the front (eg battery) and you run all the cabling (relay or not) in the front - sending a + feed to the light at the back (and earthing locally)
Or
You have power at the back and you run to the front and back to switch the light throught the switch
I would go for 1 or 3 - and would (in either) use a relay and a few fuses. Mike
Post #57928 9th Feb 2011 9:52am
BruceT
South Africa
Thank you Mike. That helps.
Post #57929 9th Feb 2011 9:59am
leeds
Probably good advice there! Razz
We have two 1 watt LED lights on the back. Total draw about 0.2 amps
The Vision X lights are a 10 Watt LED lights and draws less then 1 amp
The next jump up is 6 x 3 watt LED at 1.5 amp
Then yesterday was talking with a guy about 36 watt LED lights. Might get a play with them later in the year
So unless you are going for the big LED lights no need for a relay.
As a matter of interest what sort of current would be needed for say a 30 amp relay?
OK we have wandered off the initial topic but so what.
Please feel free to ignore me! Razz Laughing
Brendan
Post #57938 9th Feb 2011 10:32am
mse
Brendan
I said me aswell Exclamation Rolling with laughter
On the 30amp (for my spotlights) i got it at something like 0.9amp for the trigger - its fused at 1amp Mike
Post #57944 9th Feb 2011 10:41am
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Would like to see some pics of the dash open and how the wiring was done.
thanks
Post #58068 9th Feb 2011 6:47pm
