Home > Td5 > peed right off
yanto
Wales
peed right off
Had my injector seals replaced today at a local indi (oil high on dip stick)and now the landy feels sluggish! Had an alive remap 2 weeks ago and it was flying before changing them. Took it straight back and the guy didn't know why? So he put a new fuel filter on, no change. Plugged it in maf working fine. He told me to drive it for a few days and see if it improves? If not bring it back.
Any ideas what it could be?
Post #579033 19th Nov 2016 8:16pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Have the injectors been reinstalled each at the same place as before? They differ a bit and have been assigned a number which must be programmed in the ecu. If one mixes up their order, the values have to be corrected in the ecu (or the injectors put in the right place of course).
I presume your indy is aware if he knows Land Rovers, but one never knows...
Greetings,
Joris
Post #579034 19th Nov 2016 8:24pm
yanto
Wales
Like you I would like to think he has. I have read some horror stories on the net of injectors being damaged when replacing the seals?
Post #579039 19th Nov 2016 8:35pm
adseybear
Canada
take it back and get him to plug it into diagnostics.
Look at the injector correction figures. I think + or - upto 2 is alrite. Over that and you've got injector issues which you could pin on him damaging them when he changed the seals. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #579482 21st Nov 2016 6:36pm
yanto
Wales
Thanks adseybear. Called him this morning and he said drive it for a few more days to make sure the diesel doesn't entry the oil again. I think he's taking the mic! I don't like driving it at the moment, feels like I may be damaging the engine. He did say it would not damage the engine and fine to drive but it doesn't feel right. It was running so smooth before he had it. Big Cry
Post #579500 21st Nov 2016 7:46pm
I don't see how "driving it for a few days" will suddenly make it better. Perhaps you should drop an aspirin in the fual tank as well!
Mechanical parts either work or not.
Post #579630 22nd Nov 2016 10:15am
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
Not necessarily diesel_jim, if it has a good nights sleep and a run around the park before you drive off to work, it would probably make it all jump back into place and start working correctly!
Do you have a another garage you could take it to for a second opinion? Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #579663 22nd Nov 2016 2:20pm
yanto
Wales
Chris
Just worried he will say because it's been some where else he may say they have done something to it. It had a health check prior to the remap by Alive and all was good and they are prepared to put this in writing.
Post #579687 22nd Nov 2016 4:32pm
Caterham
Is it possible you're now running a standard map?
I presume he didn't do an injector learn and thought he was being helpful by putting a LR map into ecm? Presumably he knows it was mapped before it went in?
Post #579709 22nd Nov 2016 7:18pm
yanto
Wales
Yeah he knew it was remapped, I asked if the work would effect the remap. He drove it after I came back and said he could tell it's mapped and it drivers fine. But he didn't drive it before he did the work. I have driven it every day for two weeks since it easy mapped and know it's not right! Feels strangled,lumpy and has a bit of vibration. I drive the same roads to work every day and there is a steep hill on the way that it would fly up in forth, no struggling in third. I have spent 550 on new maf, remap and oil change, then 245 for injector seals. I hate confrontation and I feel this is not going to end well. Proper stressed out with it.
Post #579754 22nd Nov 2016 10:17pm
