![]() | Home > Maintenance & Modifications > Positioning of Lazer light RS-4 lights |
| nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 371
Hmmm, I was very interested in this; I have Noldens too (from Brendan of course) and wondered what this loom was. Vision-X make it and that's what Brendan used to stock. However Brendan hadn't had chance to test it to see if it worked with the Noldens. In short, as far as I can tell it definitely won't work with Noldens because the electronics inside the light extinguish the dipped beam if the main is lit, no matter what you do with the main/dipped 12V feeds. The first thing I tested was whether on 'flash' the Nolden dipped beam was on or off. It's off as expected. So, either the switch does that or the electronics in the Noldens do. So I had a look at a spare switch; all the contacts are out in the open so easy to examine. The dipped/main switch is a one-or-the other, but on 'flash' (pulling the stalk towards you) it leaves the dipped on but also puts the main on. This would work with a normal H4 bulb just fine and illuminate both filaments. However the Noldens electronics definitely switch off the dipped beam if the main beam is on. I guess this is a heat-management technique. I know LED Speaker Evos are a one-or-the-other design too. I guess Vision X lamps will work with this adaptor given they make both. Dave Green Goddess - 1998 Defender 110 300tdi |
| Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630
That's good to know Dave.. saves me spending more money..
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
| Darcy Fairfax Member Since: 05 Oct 2014 Location: London Posts: 721
Man alive, it must look daytime when that lot are on! |
| Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288
It does
| PWC1c Member Since: 10 Oct 2015 Location: Hertfordshire Posts: 196
Hi with the RS-4 in the bumper do you need the trip-R24 is it over kill ?
For most people probably yes, but I wanted as much light as possible. I live in the foothills of the Alps and have horses. Its very dark around here so having a vehicle that can light up large areas is very useful.
I will be using my Defender for driving to the ALPS and around for skiing the roads are that bit darker so the bumper option looks if it will work
Do you get Glare off the the bonnet with the tripe r
No never noticed any. It tilts so you can adjust it if its too low or high.
| Defender2014 Member Since: 25 Aug 2014 Location: Buckinghamshire Posts: 65
The Vision X units do indeed bring both low and high beam on at the same time if using the adapter lead. Have this setup on mine. If you buy the Vision X units from TMD they chuck the adapter lead in FOC. At least they used to....... Defender Puma 110XS SW Kawasaki ZX9R El Suzuki RGV250M Honda CB250N Super Dream |
| All times are GMT |
