Home > Technical > Original spec questions - 130
KGH
United States 2013 Defender 110 Puma 2.2 HT Keswick Green
Question for the experts.
What would be the diesel engine and gearbox, and which axles would have come originally on a 1987 130?
Looking at a purchase, and want to understand what has been changed. 2013 110 - Keswick Green
1995 ExRAF 110 Utility
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #578510 17th Nov 2016 8:15pm
DSC-off
A 1987 130 should have the same transmission as a 110 of the same age.
Diesel engines could be 2.5 non turbo (!) or 2.5 turboD, the pre TDi 4 cylinder engines.
LT77 gearbox.
Rear axle, Salisbury, drum brake type.
Front, disc brakes. Same as 110.
Post #578518 17th Nov 2016 8:52pm
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
As DSC said you can get the 12j and 19j engines mated to the LT77 gearbox, I doubt you'd see one with either though as they'd be just too gutless. Pretty much every 127 that I've seen that hasn't had an engine conversion has had the Rover 3.5 v8, and at 1987 should be mated to the LT85 gearbox.
Before the Defender name was introduced the 130 was called the 127 so you'd probably find more information by searching for that. 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #579594 22nd Nov 2016 2:42am
