![]() | Home > Puma (Tdci) > Ashcroft MT82 Output shaft kit - step by step guide? |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Gidday all,
I'm noticing not so much noise, but the feel of backlash when coasting and backing on and off the accelerator (the sound of backlash greatly reduced when I did my halfshafts/CV recently). I know it could be the diff or props (which I will get to eventually) but it 'feels' gearboxish to me. Anyways, I'm looking at the Ashcroft MT82 Output shaft kit: ![]() http://www.ashcroft-transmissions.co.uk/mt...t-kit.html Interested to hear your stories in installing one and how much it improved the feel (let alone improved a complete failure!). I've never gone into the gearbox or transfer, what don't I know ? Solved the bowel problem, working on the consonants... Last edited by agentmulder on 16th Nov 2016 9:02am. Edited 1 time in total |
This may help: http://www.defender2.net/forum/topic41494....croft+mt82 Darren
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
had my shaft replaced under warranty but am looking to fit this kit if and when the play starts to come back DEFENDER 90 TDCI XS,
Ohhh ![]() ![]() OK, off to read ![]() |
Okan Member Since: 17 Oct 2016 Location: Geneva Posts: 138 ![]() ![]() ![]() |
Hi all,
After the failure of my transfert box at 115000km I replaced it with a new Transfert box from ashcroft with sleeve casing and ATB inside, I altough replaced the clutch who was making some rattle because of a little spring going out, and finally I installed the ashcroft output shaft system. The old one was very dry probably installed without any grease. I will let you know about this setup, but what I can tell you is that it totaly supressed the horrible "Klong" noise when I was changing a gear. The only thing I can hear now is a little continuous noise of whistling, but I'm not sure if it comes from the transmission or maybe it's just my turbo that I didn't hear before that anymore. Best regards |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 238 ![]() ![]() ![]() |
Hi Okan,
My gearbox went after 153.000 last weekend. Just looking at the options available. I saw Ascroft's what is meant by a sleeved casing (I saw that on the options list too)? Best regards |
Double post, sorry.
Td5 Member Since: 29 Jun 2015 Location: Finland Posts: 53 ![]() ![]() ![]() |
Hi, You chaged CV-joints & half shafts?
In my 07 90 was the rear half shaft splines quite worn. Same with all drive shaft flange splines. I changed rear half shafts and all drive flanges. Also I installed the Ashcroft output shaft kit. Perhaps I should check the pinion back lash. I think the Puma clutch is more on/off than 300Tdi. Actually I like th 300Tdi 90 Defender much more than the Puma. Somehow there is more character in the 300Tdi. Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 264 ![]() ![]() |
See : Linkhttp://www.ashcroft-transmissions.co.uk/di...asing.html Dave |
