![]() | Home > In Car Electronics > Led side and rear |
| Shax Member Since: 05 Oct 2010 Location: London Posts: 391
I got mine from Mud Stuff.. Work great and look pretty cool too... I wouldn't mess with LED bulbs..
It's LED indicators that cause issues.. They need a proper LED flasher relay, or a bloody great resistor to work.. If you get LED indicators, get the proper relay, so much less aggro!! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21026
You can change them all with no issues even the side repeaters.
It's front and rear indicators that you need the Relay for. Even then, easy to sort out no problem. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347
I'm with Steve on this.
A doddle to fit and the difference is amazing - especially on dark country lanes. Get the flasher relay - particularly if you intend to tow. I got mine from Bolt On Bits (RDX) via eBay and never looked back |
It's just best with front and rear indicators to fit the full set front and rear and Relay at the same time in my view.
The rest you can change bit by bit when ever you like. I fitted LED's to mine in stages, mainlu due to getting some @ Xmas given to me etc. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
