![]() | Home > Maintenance & Modifications > Cubby Box Firdge |
xcentric Member Since: 17 Jan 2016 Location: Midlands Posts: 247 ![]() |
I've no idea if it fits, but the Discovery's have a middle cubby box fridge that is approximately the right size - it may be a bit tall and narrow, however. Worth measuring.....
barrowg Member Since: 31 May 2016 Location: Surrey Posts: 244 ![]() ![]() ![]() |
would it be possible for you to whip me link for one. no idea what I'm looking for!!
Thanks |
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 ![]() ![]() |
Does it have to be in the cubby?. Why not just put a permenant live 12v socket in the back and have a portable cool box/fridge. That's what I have and it works so well and you are not limited to a certain size.
I'd prefer to have it in the cubby box and out the way
not near mine so can't measure it, but the inter web should have the info somewhere.....
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1066 ![]() ![]() ![]() |
The metal around my cubby box gets warm to the touch on a long journey - will the fridge cope?
The Discovery cubby fridge is a very different shape to a Defender cubby, plus it uses the standard cubby box lid, which is part of the centre console. I can't see it being worth the faff of trying to make it work, particularly given their price.
![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
would you say it would better to convert my cubby into a fridge then...? easily done using some simple computer cooling parts
(Sorry bit of a tech geek) ![]() ![]() |
you either need a peltier plate, or an evaporative cooling system. But simpler would be to find a small portable fridge unit that basically fits, then upholster it.
i was going to use a couple peltier plates then attach stainless steel to the inside of the cubby?
any ideas?? tia |
Yeah, that'd be an interesting project and probably give more useable space than the Discovery one, which is really quite small inside. Darren
