![]() | Home > Technical > Instrument Panel Tow Light Stays ON |
| Castillo Member Since: 23 Nov 2012 Location: Tavastkyro Posts: 41
I have same problem in my defender td5. I replaced some days ago all old original 73mm lights with new wipac led lights and so this tow light stays on. Why? defender 110 td5 2006
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Click image to enlarge it driven by switch at the top, be place to start on the 300tdi |
| quantumfoam Member Since: 20 May 2016 Location: Newcastle Upon Tyne Posts: 12
Thanks for the electrical schematic it is very helpful. Will let you know if and when I get a solution. In the meantime I have removed the tow ball and socket
I changed the instrument panel led for an original bulb and everything worked so will leave it like that with original relay for the moment and change out the relay for a one suitable for led's later. Well it also passed the MoT although I had to make sure the smoke out the exhaust was reduced. Did this via a diesel treatment and cleaning out the air intake. As I didn't have a lot of time prior to the MoT test I used a less conventional method than removal of the intake (see attached pics). Now its a proper clean including removal of the intercooler and also the vent system pipes. Thanks for all the help.
