![]() | Home > Off Topic > Cheap Chinese plasma cutters - anyone got one? |
Buy once, buy right.
As you 'need' one ![]() Spend money, not waste it. |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I've seen a few cheap ones, it mainly comes down to the thickness you want to cut?
Cheap ones will be ok for panel work up to 2/3mm? I ended up with one from Parweld, not cheap but well worth it. Once you have one, you will have wished you brought one a long time ago! 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 731 ![]() ![]() ![]() |
Bought one around 6-7 years ago, for around that sort of money. Giant, I think it's branded. I only bought it to do a bit of messing around with and to do odd jobs and can whole heartedly say that it's never let me down, does exactly what it's supposed to do and can cut up to 6-8mm at a push. I'm not usually one for buying cheap Chinese things, but just recently the quality seems to have gotten a lot better, so long as it's branded. I say if your not making a living from using it and not using it very often, why spend £1500 or more on something that will do exactly the same thing for £200.
Your money, your choice however. Last edited by BuckBlu110 on 9th Nov 2016 11:27pm. Edited 1 time in total |
Factor in a compressor too.
We've got a Hypertherm 30A at work which we got second hand. I want to say that was £500. I think if I was buying one I'd go for a size bigger. If you look at the cost of consumables, if you actually get the claimed life out of them then it should cost a little bit less (not much) than cutting things with a cutting disc on a grinder. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3824 ![]() ![]() |
I too have looked at these and also the small 3D Printers...
At the prices they are its probably worth a try, if you get one and not happy you can always ebay it and probably get your money back... Let me know if you go for one and how it is. Anyone with one can they do a small engraving for me? (please) around 5cm by 5cm text? ---edit its not a plama cutter I'm after a laser engraver ![]() http://www.ebay.co.uk/itm/NEJE-DIY-1000mW-...SwaB5Xp-qt |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 ![]() ![]() ![]() |
Hi.
Try looking around this link, the good, the bad and down right dangerous. elcheapo chinese machines, some are good, others well not so. Lots of info on this site for all sorts of metal fabrication . http://www.mig-welding.co.uk/forum/forums/plasma-cutters.34/ |
