![]() | Home > Td5 > Doors not latching |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2272 ![]() ![]() ![]() |
My passenger door appears to suffer with the temperature RoddyK05 - I thought it was just me
![]() My wife (the main user of said door) said that it only happens when the temperature drops and I think she's right. Both my striker plates are relatively new (and have the nylon bush in tact) and they close perfectly in the warmer weather ![]() I look forward to reading any suggested remedies |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
I found the answer to this and Geobloke did a nice write up over on Land Rover UK Forums:-
http://forum.landrovernet.com/content.php/...How-to-Fix Probably worth making this a sticky as it's such a common problem as we approach colder climes... Dave Green Goddess - 1998 Defender 110 300tdi |
Good man Dave and thank you
![]() ![]() I shall look at that over the weekend and report back if I cure it! If it works I'll claim all the credit with the missus ![]() Cheers, Will |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 ![]() ![]() ![]() |
Fantastic, I'll be giving that a go at the weekend - although I would have said mines were pretty clean, but a proper clean and re-grease can't do any harm at all. Here's hoping.
![]() Don't forget the last instruction - it's the most important one ![]() ![]() Green Goddess - 1998 Defender 110 300tdi |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 ![]() ![]() ![]() |
Desperately need to do this to mine too - my passenger door no longer closes! 2005 Td5 | 90 Station Wagon | Tonga Green
Well spank my ass and call me Charlie!
It worked a treat after a few minutes work as described by nosnibod and geobloke ![]() Next time you're up this way, you will be treated to a pint ![]() |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 ![]() |
I'll be giving this a go as the cold weather door gremlins have started. ![]() |
SteveK Member Since: 21 Jan 2015 Location: Bromsgrove Posts: 335 ![]() ![]() ![]() |
Try X Engineering replacement latches. The useless/soon damaged nylon bush is gone and the latch is much less likely to rip your jeans or trousers!
http://foundry4x4.co.uk/index.php?route=pr...duct_id=68 Adjustment is easy and my 110 TD5 doors now close with a gentle push! |
Just done mine. Completely bunged up with accumulated spray grease, dirt, dust, dog hair etc. Now clean as a whistle. I lubricated them again with PTFE dry lubricant in the hope they won't accumulate the grime again as quickly, but we shall see. Certainly sound a lot better and passenger door now seems to be closing, so will see how it goes over the coming weeks. Thanks to nosnibod and Geobloke for the advice
Done mine today
![]() Well that was a nice easy job to do,but very satisfying. Doors all looking a lot better now. Just followed the instructions. Thanks for the link Nosibod ![]() |
Down to Halfords today for brake cleaner and white scooshy grease. Done in no time, it seems to be better but I await a drop in the temperature again for the acid test. It can't fail to have made a difference, hopefully that's it for a while. As others have said, thanks a lot for the link, it shows just how good forums like this are when people need a wee helping hand.
mactheknife Member Since: 08 Jul 2016 Location: Somerset Posts: 51 ![]() ![]() ![]() |
Same issue here. Strange its always the passenger side!
Brake cleaner does the trick. |
