Home > Maintenance & Modifications > MOT.......
Screbble
MOT.......
It's my MOT on Friday and I am hoping for a pass with no advisories as in previous years (kiss of death Neutral )
Thought I'd run this past you wise and learned ones. Since the last MOT I've fitted a steering guard and wonder if the recovery eyes will catch the attention of the tester?
Even if they do, would it cause concern?
Secondly, and this is a real daft one. I replaced my o/s front seat belt before the test last year as it was showing signs of fraying (not because of jamming in the door!).
Well look at it now....
Can you guess what caused this?
Jack bloody Wolfskin!
Would you believe that the Velcro has torn the new one. Well, it may be obvious to you but it wasn't to me. I'm not sure it's a fail but I have another new belt on the way. I'll be fitting it for MOT's only Rolling with laughter
Post #576385 8th Nov 2016 10:39pm
ickle
a split tennis ball or similar pushed over each of the eyes?
Post #576391 8th Nov 2016 10:52pm
Screbble
Of the steering guard or the tester Rolling with laughter
Thanks for the pointer ickle, I may just do that!
We can only wait and see Thumbs Up
Post #576392 8th Nov 2016 10:56pm
ickle
Is it Red Nose Day soon?
Might be a good place for a pair of red noses!
Post #576393 8th Nov 2016 10:58pm
Steering guard should not even be mentioned on the MOT. I have two tow jaws on my front bumper, they've never been commented upon.
Re. the seatbelt, mine looks similar, and all I do is carefully trim off all the "fluff" before the MOT. Again it has never been mentioned. A seatbelt should need far more severe damage than that to merit failing.
Incidentally I now have one of those padded sleeve thingies on the belt to prevent further velcro damage.
Post #576401 8th Nov 2016 11:42pm
Screbble
Thanks for the reassurance Blackwolf Thumbs Up
I'm sure the recovery eyes won't be an issue unless he bangs his leg on them Rolling with laughter
I reckon you're right on both counts. The seat belt is certainly more cosmetic than structural. Can you believe how it got damaged!!! Embarassed
Post #576402 8th Nov 2016 11:46pm
Hope you don't get an idiot of a tester like I did.
Probably just my bad luck.
Maybe your wing mirror extrudes beyond panels too far. Whistle
I'm sure it'll be all okay. Thumbs Up ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #576410 8th Nov 2016 11:58pm
Screbble
To be fair Steve, the guy I use is normally ok, but prompted by your recent experience I'm just preparing for some hassle Neutral
Having focussed on those two items, you can bet your bottom dollar I'll be hit with something else Big Cry
Still, it will be what it will be and I will look forward to fitting my Scenelite once I've got a clean bill of health Thumbs Up
Post #576414 9th Nov 2016 12:06am
Screbble
Yes they're only a few quid in Halfords Thumbs Up
Post #576415 9th Nov 2016 12:08am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Singe the frayed belt with a lighter, it will give it a nice appearance and then pass the test, I would advice a new one sooner than later as the cost of a belt is nothing with the cost of you Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #576472 9th Nov 2016 11:02am
Screbble
Cheers Mash Thumbs Up
It was a brand new belt for the MOT last year and another was ordered on Monday.
I agree, at circa £40 it's not worth cutting (or fraying) any corners.
I'm going to show the (removed) frayed belt to the tester and see what he says. I reckon its fine Thumbs Up
I'm keeping the new belt as my 'MOT belt' only and its going back in the box after each test Rolling with laughter
My wife may have a different view to you though Neutral
Post #576475 9th Nov 2016 11:14am
Mash
Depending on the tester, any extensive fraying/cuts to the outer edge or any holes a biro nib can pass through are a fail. If you are changing it depending on what locking method you have for the nuts make sure you check those too, it's often Nylocks and if so these should be fitted new each time as they are a one time use. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #576478 9th Nov 2016 11:25am
Screbble
I shall report back on Friday.....
New nylocs (and washers) fitted last year and new ones ready and waiting on the bench for this installation Thumbs Up
I took the opportunity last year to fully inspect, clean and paint the area underneath the lower mounting - it's like brand new Thumbs Up
I even applied a film of Tefgel..... (OCD) Wink
Post #576480 9th Nov 2016 11:36am
excossack
No issues with swivel eyes on my bumper and as for frayed seat belts, the tip from my MOT tester was to wave a lighter over the fibres and remove them! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #576490 9th Nov 2016 12:22pm
DAZ110
Post #576997 10th Nov 2016 11:12pm
