Home > Technical > Decent Mounting Point for dual USB?
big110
 2014 Defender 110 Puma 2.2 SW Keswick Green
Is the area to the left of the diff lock instructional sticker accessible? I would like to mount my dual USB socket there but unsure on
1. How to remove this panel
2. is there anything behind it prohibiting me from doing so
Thanks!
Post #576053 7th Nov 2016 4:02pm
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
Why don't you change the cigarette lighter for one?
Post #576056 7th Nov 2016 4:34pm
big110
Well still use that socket for me GPS
Post #576057 7th Nov 2016 4:36pm
jrule
Post #576060 7th Nov 2016 4:43pm
1978
United Kingdom 2003 Defender 90 Td5 HT Belize Green
You can more than likely buy a USB cable to power your GPS, I have replaced my cigar lighter with this double USB socket:
http://www.4x4overlander.com/product/blue-sea-twin-usb-socket-2/
It's a great bit of kit.
Post #576061 7th Nov 2016 4:44pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
I put one on the cubby, on the sloping bit
Post #576121 7th Nov 2016 10:27pm
kmac
Re: Decent Mounting Point for dual USB?
You could remove the main panel with the stereo and switches and then have a look there
Post #576122 7th Nov 2016 10:29pm
big110
is there a step by step for getting that face panel off? great idea.
Post #576125 7th Nov 2016 10:40pm
Hardwire a power feed for it coming out the dash top, a lot easier and neat. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #576135 7th Nov 2016 10:58pm
Alien
Australia
To get the facia panel out its only 2 screw and 6 or 8 clips.
Remove the 2 torx screws and the panel unclips.
Some people use small screw drivers or similar to lever the panel out but watch you don't do damage where you push.
It will be tight and the radio stays attached to the panel.
Once loose unplug the clock and any switches as nessasary to move the panel for access.
The plugs are switch specific so will only refitt to origional positions.
I don't think you'll get the USB outlet in your preferred location due to the heater box behind it.
Have look up in there from the passenger's foot well.
I fitted our outlet near the passenger grabs handle so the shelf below it can store the item being charged.
Piggy back of the back of the cigarette lighter for power and earth to keep the USB on the accessory circuit. Cheers,
Kyle.
Post #576144 7th Nov 2016 11:33pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
Mind that most double USB ports are 2A. If you hook up 2 devices, it will supply 2A in total, not 2x2A. 1A wouldn't be enough for most larger devices like a tablet or power hungry smartphones that are working hard.
If I have a phone or iPod and my 7" Sony tablet connected, the tablet will only keep it's charge when I limit the number of open apps to one or two.
Mine is the blue sea double USB hub. If I'm not mistaken there's a 5A USB port on conrad.com.
Greetings,
Joris
Post #576169 8th Nov 2016 7:11am
big110
def want the blue sea 4.8amp dual socket. Been using Blue Sea forever, GREAT products
Post #576524 9th Nov 2016 3:26pm
jst
Does anyone have a link to the blue sea 4.8a one please? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #576554 9th Nov 2016 6:08pm
big110
https://www.bluesea.com/products/1045/Fast...cket_Mount
You will know you're buying the 4.8amp instead of the 2amp because it's 2x the cost LOL
Post #576557 9th Nov 2016 6:11pm
JOW240725
I had a few added.
The one in the glove was specifically to run the satnav, but unfortunately it doesn't like it and keeps rebooting Big Cry James
Instagram @suffolk_rovers
Post #576579 9th Nov 2016 7:30pm
