![]() | Home > In Car Electronics > I have DAB! |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
how did you mount the DAB arial?
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 ![]() ![]() |
On the top right of the windscreen, The ariel came with the unit as well as a microphone for the bluetooth call making. So I removed the A pillar cover, ran the wires behind the instrument cluster and up the side of the screen.
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2063 ![]() ![]() |
Did you enjoy scrapping the paint off the A pillar for the aerial connection ?
i take it the aerial is an internal stick on then?
Yeah came in the box. i'd done some research on here and the rest of the net about dab aerials and if fitted right they seem ok.
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 625 ![]() ![]() ![]() |
I fitted an external one in the place of the original, was a bit pricey though, £47 if I remember correctly, worht it though
![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
Didn't need to scrape anything, as long as the earth tab was on metal it was fine. The fact that you stick it to a surface surely can't mean it's vital it's bare metal
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
Fit an external one ! Miles better than the screen mount
If i have issues at some point with reception then i'll look into an alternative
mse Member Since: 06 Apr 2008 Location: UK Posts: 5103 ![]() ![]() ![]() |
Just fit a unit and use the factory original aerial for dab
